RELAY Omron
Good evening
Own a Reality
The outer cover is written on it
RELAY Omron
MY2N-J
IEC155
5A 250VAC
5A 240VAC
5A 28VDC
There is a paste on the internal file written on it
12VDC
File connection points 13-14
The question is, can I connect it directly to AC electricity?RELAY Omron MY2 (1) (1).jpg
Not the coil. The coil is rated for 12 VDC as rated.
Contacts yes, to turn on a load, seem to be rated for 5A. That would be
a series connection to load.
Regards, Dana.
Normally on Omron relays, they have the terminal diagram on the side of the cover.
The bottom left terminal pair in the picture is the coil. you can see what appears to be a LED indicator connected to it on the RH side .
BTW, if it does have the LED indicator as it appears, the correct 12vdc coil polarity has to be observed.
All the Omron cube relays i have used, have the diagram/legend of the connections on the top of the cover
Greetings to all, thank you all for the replies
What do I mean, can the relay be connected to an alternating current source between point 13 and 14
Regards, ADEL
AS PREVIOUSLY ADVISED THE COIL IS 12VDC, NOT AC.
GET A RELAY WITH AN AC COIL OF THE CORRECT VOLTAGE IF YOU WANT TO CONNECT AC TO THE COIL ON TERMINALS 13 AND 14.
AND YES THIS REPLY IS IN CAPITALS FOR A REASON!
If you only have an AC source, then use a small bridge rectifier to supply the coil.
Observe the right polarity.
Because inductive reactance, you would have to put in more VAC than VDC. The peak DC voltages will be 1.414V higher than the ACRMS voltage. Either unusually large peak could damage the integrated LED, most likely the reverse half cycle.
Also many fake OMRONs out there, ONROM, OMRQN. I accidentally bought thirty or so. They do work, but coils vary more than expected. DC will be safer than guessing current into an unknown reactance.
