OLD? They made them for a long time. Don't know when they stopped. If age
bothers you, find a newer one, but some of the older wones were the best
IMO.
I don't mind old stuff, I have lots of it. In this case though, the
older versions are better in some ways, but not in the most important
ways IMO. It's much the same with my old tractors. They're good in
that they're relatively easy and cheap to repair, but in terms of
efficiency and productivity, their designs were outclassed decades
ago.
Sorry, I don't know anything about your neighbor so I can't argue about
that, but I can tell you about my Onan because I have known it since it was
new. It was perhaps 30 years old when I bought it from my employer. Except
for sparkplugs and batteries, it was all-orignal. Nothing had ever broken!
To be honest, after I bought it, I did have some problems with points.
Perhaps the problem was the mechanic (me). Anyhow, I solved that issue with
an electronic ignition conversion.
There is a germ of truth here.
We are talking about something that was
designed when gas cost 50 cents a gallon! There are certainly more
efficient generators around, but they are not cheap and you are unlikely to
find them at Home Depot. Fuel cost is important (OK, damn important), but
it is not the only cost of running a generator..
Let's make a fair assumption that the flat-head penalty is 20%. For
every gallon of fuel burned per day, by using an overhead valve engine
one could save enough in a single year to buy an entire spare 13 hp
engine!
Running at 1800 RPM (vs 3600 RPM) drastically lowers the pumping loss of the
engione (increasing efficiency),
But they're *not* as efficient as OHV competitors. If they were, then
Onan wouldn't have switched to OHV.
greatly decreases noise, and reduces wear.
Somebody wrote that these engines can make 10,000 hours before the
first rebuild. But didn't Ulysses get more than that out of an EU
engine? Yes, the Onan can be rebuilt over and over, but what's the
point if that costs more in the end?
"Better" (commercial quality) engines are expensive
I didn't mean commercial quality, only anything with a cast iron bore
and a decent oil filter.
and are not found on
consumer-grade generators. I expect my Onan to outlast me. I can't say that
about any other small engine I own.
One can say the same about an old power drill for example. But it's
still more practical and cost-effective for most to buy a modern
drill.
No, you can't throttle a conventional generator down to lower speed if you
want 60 HZ power.
True, but most of the DIYers here seem to be using belt-driven
arrangements. My own is overpowered (larger displacement considering
the output, just like the old Onans), and is throttled down to about
2000 RPM.
pumping loss of the engione (increasing efficiency), greatly decreases
noise, and reduces wear. Yes, you could design your own generator with a
throttled-down 3600 RPM engine and a belt ratio to get the proper frequency,
but you would no longer get rated power from the engine.
Finally, these (Onan) generators are made for motorhome use. They must fit
into a minimum space, must have reliablility comparable with the vehicle's
engine, and must run with minimum noise and vibration. My neighbors don't
even know that I have a generator because they can't hear it!
Aren't the new Onan RV generators 3600 RPM? Then it seems that lower
RPM isn't the single secret to low noise. Anyway, if we're trading
anecdotes, my neighbor with the old Onans was impressed with the quiet
of my plain-jane Kohler in a simple enclosure.
Wayne
