Cliff
Besides, there had to be lizards before there could be a chicken to
evolve...
Fred & Barney told you that one?
evolve...
Actually, the reptiles came first...
Cliff said:You think so? Why?
So you are claiming that the laws of Physics change?
About that Aluminum foil ....
Oh boy. There had to be sharks before we could evolve, if you wantMan, you need to let your undies out a little.
Ever hear of this thing called "humor"?
evolve...
"Floyd L. Davidson"
** Piss off - cable tugger idiot.
"Floyd L. Davidson"
Paul Hovnanian P.E.
** Moose Stoopid and plain wrong.
It creates opposing polarity loops.
The included loop area of the pair must always be minimised.
Take no notice of this " Floyd " idiot cable guy wanker.
"Fred Bloggs"
** That is both false and silly.
And you are a lunatic.
The length of a conductor in the braided shield is quite long
between two points while it may be much shorter with
a foil shield.
Considering the speed of the electrical field in
the conductor ..... and the distances involved ...
but the center conductor is shorter than the conductors in
the braid ...
Why? Consider a superconducting loop with an induced current ...
You can stuff quite a few electrons on the surface of a
sphere .... see Van de Graff generators ...
NunYa Bidness said:More retarded remarks from the phil twit.
You must be one of those bastards that are related to the fucktards
that were jailed in that continent many years ago. Your mentality
sure supports this conclusion.
You piss off, you retarded bat's turd!
NunYa Bidness said:Ever notice how you get no response to your utter stupidity,
fucktard?
F.D. has your grasp of the realm beat by orders of magnitude.
NunYa Bidness said:You're a fucking retard. LF mag fields can pass through the planet.
They most certainly can be read right though a coax shield.
Run it through a steel or mu metal pipe, and THEN things change a
bit.
YOU are both false, and retarded. Your ancestry is showing.
I worked for a short time pumping figures into a VAX that "nested"
cut shapes together to minimize material losses in a sheet steel
plasma cutter setup.
plasma cutter setup. We had 3 machines, but the last one never
worked. It was a mere 150' feet from the VAX based machine controller
apparatus.
I noticed that the 9 conductor, foil shielded cable they used to
connect to the machine 150' away was draped directly over and snaked
around heavy power conduits that fed some of the high power machinery
being used in the shop (welders, shears, brakes, etc.).
I told them the reason their machine did not work was the routing of
that cable, as the spec for that particular serial line could traverse
much farther than a mere 150'. The noise introduced by the power
conduits was enough to keep the ports from handshaking/establishing a
connection for data transmission.
They bought a new cable, and routed it a bit better, and the machine
now functions.
there's some current
That's just nuts! A braided shield's conductors contact each other
throughout their length,
and the electrical equivalent length is no
different than that of foil shield.
You're nuts. If they were coated mag wire, you would be closer to
being correct, but braided shield is by design co-conductive elements.
