Bill said:
You get the same advantage by putting an analog multiplexer after a
single sample and hold and using it to feed four parallel box-car
integrators - the multiplexer doesn't have to be up to much.
I repeat - where is the digital advantage?
My copy of Floyd M. Gardner's "Phaselock Techniques" is the second
edition, published in 1979 (ISBN 0-471-04294-3) but the first edition
dates back to 1966, and the introduction refers back to Bellescize's
paper in the French "L'Onde Electrique" vol. 11, pp 230-240 (1932) on
synchronous/homodyne radio receivers. Your heroes seem to have
performed the not-unfamiliar trick of stuffing an A/D converter into a
well-known system and then making exaggerated claims about the
improvement in performance they got.
As Mr. Bloggs stated, the amplitude error of the quadrature demodulation
approaches zero, since only one sampler is used. No analog circuitry
follows to add DC offsets or any amplitude errors. Also, a very precise
90 degrees can be acquired digitally, so the "LO" phase error will be
quite low too. Of course, a digital 90 degree phase splitter could also
be applied to an analog IQ decoder/demultiplexer, and sometimes is. I
think the digital advantage, so to speak, is eventually to be had in
high integration and low cost -- the detector/demultiplxer/decoder and
entire BB analog section can be eliminated. In truth, both methods are
still used, and conventional superhet designs can largely mitigate DC
offset problems.
At my previous employer, we used bandpass-quadrature sampling at 5/4
wavelength. As a result, we had no DC, amplitude, or phase error
issues. The conversion to digital (which has to happen anyway), the
downconversion, and the IQ decoding, is done in one fell swoop. Analog
I/Q demodulators always have some measure of DC, amplitude, and phase
issues.
