JimG said:
Looks like my crude preamp circuit is going to work. I've been able
to increase the gain to 1500, which at 1.2kHz is holding up OK on the
LF411CN op amp.
If you use two opamp stages with equal gains of about the
square root of the gain of your single stage, you will get a
much better frequency response that you are getting, now.
The source signal from the chopper amp is indeed close to 15uV p-p,
which gets amplified to almost 25mV. This is a couple of divisions on
my Scopemeter and is easily visible.
But there is still a fair amount of noise on top of the basic 1.2kHz
signal. Any further suggestions for cheap ways to reduce this noise
are welcome.
A different scope would help a lot. An old analog scope
with a phosphor screen would be better at visually averaging
many traces, so that the brightest part of the image would
be a lot smoother than you get on a scope meter. But better
digital scopes include a signal averaging choice that
mathematically averages multiple passes, and displays the
average. That would really clean it up. Perhaps you can
borrow one.
It's not clear to me if something like the Minicircuits GALI-39 that
ninja suggested is still appropriate for a 1.2kHz signal with 0.05 ohm
output impedance.
No. Dropping the frequency requirement by 1000 means that
opamps are right in their sweet spot. But you could benefit
from one that has very low voltage noise for the first gain
stage, like an LT1028 or LT1037 or OP27, which all have
lower input noise than the LF411.
LF411 with about 25 nV/Hz^.5 at 10kHz:
http://cache.national.com/ds/LF/LF411.pdf
LT1028 with about 8 nV/Hz^.5 at 10kHz and over 10 times the
gain bandwidth product:
http://www.linear.com/pc/downloadDocument.do?navId=H0,C1,C1154,C1009,C1026,P1235,D3480
LT1037 with about 2.5 nV/Hz^.5 at 10kHz and about 20 times
the gain bandwidth product:
http://www.linear.com/pc/downloadDocument.do?navId=H0,C1,C1154,C1009,C1026,P1212,D2204
OP27 with about 10 nV/Hz^.5 at 10kHz but less than 1/5th the
http://www.analog.com/UploadedFiles/Data_Sheets/OP07.pdf
