Platforms
Content
The dishes comes to mind.The fact is ... Bob is sharp as a tack. I don't think he needs help with anything.
Chris
I really didn't understand that. I mean .. like I stared at it for a few minutes struggling to figure out what it meant. Then it dawned on me that this is what my wife says I don't know how to do. I'm glad I never learned that science.The dishes comes to mind.
Bob
http://www.diodes.com/_files/datasheets/PAM8610.pdfI bought 4 PAM8610 based stereo amp modules. I will use them as 2 mono amps as before.
rtrg,
As they are stereo amps and you only want to use one channel, you will need to put a load on the channel you are not using. (some homework for you).
PS. DC centre pin is +
I could not get the board to function despite the lit power led. 2 speakers connected, stereo plug, 12 volt supply, volume at full. I bought a small stereo 12 volt dc supplied amp. Cigar box sized. Am already using one with my other back up. Can put it behind the flat screen out of the way. It also has a usb for power. works well.That Mute pin will only mute when either connected or not!.
It is not an important part of your wiring.
You can leave the link in place or put a switch in its place. You wont damage the board.
Martin
