Power Dissipation Across A Transistor In Cutoff
Assume Vce(sat) is 0V and that the other two transistor's input pin is equivalent to their base resistor to ground.
Those conditions lead to a slight overestimate
This calculation of current is trivial and I would be profoundly disappointed if you can't do it.
Sry, english is not my first language. this answer is in regard to which question ?
The one you asked immediately prior to me posting it, and then repeated immediately after I posted it.
What is the voltage on the collector of q201a (or whatever the first transistor is)?
I'm working through the "why no more than 1mA" question.
The voltage on the collector of the first transistor is (volatge at Tm+ - diode drop - transistor drop )
if Tm+ is 8v , (8-0.7-vcesat(of transistor)).
Am I wrong ?
Yeah, sorry, you're right. I misremembered it.
Now you have that, assume the entire load is the resistor between the input terminals and bases (assume Vbe is 0V).
What current will flow?
the current then will be the voltage at collector divided by the resistance. oh ok , I guess I had a confusion regarding the Vbe . So I have to assume the Vbe to be 0 ? right ?
Can I trouble you with one more doubt Steve ?
when the voltage at TM+ is 6V , i understand that the first transistor doesn't turn on . now the current is given in the datasheet as Iceo (collector to emitter cutoff current) , but what is the voltage at the collector (P203) ?
You can use ohms law if you want to, but you can often consider the current through the transistor to be zero (I think they specify a maximum value of some small fraction of a milliamp, but I can't remember it off the top of my head)
Would I be right in considering the resistors as in parallel ? (the base resistors of transistors)
Yes, but in this case you need to consider both the input resistor and the base/emitter resistor in series. (And then both of them (one for each transistor) in parallel).
What current are you assuming?
How do I calculate the voltage at the collector of the first transistor ?
