No, there are different "lithium" chemistries, and the Energizer E2
Lithium is a native 1.7 or 1.8 volt cell. AA cells are roughly 3 ah
each, and loose less than 1% per year to self discharge.
Here's a bit of info on 1.5 volt nominal lithium chemistry. From
http://en.wikipedia.org/wiki/Lithium_battery
Li-CuO Copper oxide 1.5 V 2.4 V
Can operate up to 150 °C. Developed as a replacement of zinc-carbon
and alkaline batteries. "Voltage up" problem, high difference between
open-circuit and nominal voltage. Produced until mid-1990s, replaced
by lithium-iron sulfide. Current use limited.
Li-Cu4O(PO4)2 Copper oxyphosphate
See Li-CuO
Li-CuS Copper sulfide 1.5 V
Li-PbCuS Lead sulfide and copper sulfide 1.5 V 2.2 V
Li-FeS Iron sulfide Propylene carbonate, dioxolane, dimethoxyethane
1.5-1.2 V
"Lithium-iron", "Li/Fe". used as a replacement for alkaline batteries.
See lithium - iron disulfide.
Li-FeS2 Iron disulfide Propylene carbonate, dioxolane, dimethoxyethane
1.6-1.4 V 1.8 V
"Lithium-iron", "Li/Fe". Used in eg. Energizer lithium cells as a
replacement for alkaline zinc-manganese chemistry. Called
"voltage-compatible" lithiums. 2.5 times higher lifetime for high
current discharge regime than alkaline batteries, no advantage for
low-current applications. Low self-discharge, 10 years storage time.
FeS2 is cheap. Some types rechargeable. Cathode often designed as a
paste of iron sulfide powder mixed with powdered graphite. Variant is
Li-CuFeS2.
Li-Bi2Pb2O5 Lead bismuthate 1.5 V 1.8 V
Replacement of silver-oxide batteries, with higher energy density,
lower tendency to leak, and better performance at higher temperatures.
Li-Bi2O3 Bismuth trioxide 1.5 V 2.04 V
The E2 is Lithium Iron DiSulphide.
They have a self protection circuit built in - a self resetting
poly-fuse type apparatus callet a PTC (Positive Temperature
Co-efficient) This also makes it almost impossible to detonate the
battery by attempting to recharge it. The battery is limitted to 2
amps continuous, but can handle short duration higher peaks
significantly higher.
They CAN BE SHIPPED BY NORMAL METHODS INCLUDING MAIL.
You need to learn to do your research before you make statements you
cannot support. You've proven yourself to be a blowhard.
