Rod Speed ha escrito:
Why? Because you say it? Oh please...
You say that because probably you don´t have a clue about how a
battery charger works.
No, there are different "lithium" chemistries, and the Energizer E2
Lithium is a native 1.7 or 1.8 volt cell. AA cells are roughly 3 ah
each, and loose less than 1% per year to self discharge.
Here's a bit of info on 1.5 volt nominal lithium chemistry. From
http://en.wikipedia.org/wiki/Lithium_battery
Li-CuO Copper oxide 1.5 V 2.4 V
Can operate up to 150 °C. Developed as a replacement of zinc-carbon
and alkaline batteries. "Voltage up" problem, high difference between
open-circuit and nominal voltage. Produced until mid-1990s, replaced
by lithium-iron sulfide. Current use limited.
Li-Cu4O(PO4)2 Copper oxyphosphate
See Li-CuO
Li-CuS Copper sulfide 1.5 V
Li-PbCuS Lead sulfide and copper sulfide 1.5 V 2.2 V
Li-FeS Iron sulfide Propylene carbonate, dioxolane, dimethoxyethane
1.5-1.2 V
"Lithium-iron", "Li/Fe". used as a replacement for alkaline batteries.
See lithium - iron disulfide.
Li-FeS2 Iron disulfide Propylene carbonate, dioxolane, dimethoxyethane
1.6-1.4 V 1.8 V
"Lithium-iron", "Li/Fe". Used in eg. Energizer lithium cells as a
replacement for alkaline zinc-manganese chemistry. Called
"voltage-compatible" lithiums. 2.5 times higher lifetime for high
current discharge regime than alkaline batteries, no advantage for
low-current applications. Low self-discharge, 10 years storage time.
FeS2 is cheap. Some types rechargeable. Cathode often designed as a
paste of iron sulfide powder mixed with powdered graphite. Variant is
Li-CuFeS2.
Li-Bi2Pb2O5 Lead bismuthate 1.5 V 1.8 V
Replacement of silver-oxide batteries, with higher energy density,
lower tendency to leak, and better performance at higher temperatures.
Li-Bi2O3 Bismuth trioxide 1.5 V 2.04 V
The E2 is Lithium Iron DiSulphide.
They have a self protection circuit built in - a self resetting
poly-fuse type apparatus callet a PTC (Positive Temperature
Co-efficient) This also makes it almost impossible to detonate the
battery by attempting to recharge it. The battery is limitted to 2
amps continuous, but can handle short duration higher peaks
significantly higher.
They CAN BE SHIPPED BY NORMAL METHODS INCLUDING MAIL.
A lithium cell WILL produce 3V regardless of it´s type. A rechargeable
lithium battery or a non rechargeable one will have the same voltage
output. That´s what the chemistry produces, and you can´t reduce that
voltage chemically, so they must have some built in electronic method
to reduce the voltage to the standard 1.5 V a AA cell should produce.
You need to learn to do your research before you make statements you
cannot support. You've proven yourself to be a blowhard.
Except the Lithium E2, which is a non-rechargeable battery
(officially) The PTC device prevents them from being charged too hard
or overheated if inadvertently put into a charger.. They WILL accept a
charge - I don't know how much capacity the recharged cell has yet as
I have not tested it. I charged it with a regulated power supply
current limited to 350ma and voltage limitted to 1.65. I need to crank
both current and voltage up a bit to get a full charge - the battery
was at .7 volts when I pulled it out of the clock and after two hours
it is at 1.2 and has held that voltage for 3 days. I'm going to rig up
a proper holder, then put the battery outside on the charger for 5
hours at 500ma and 2.35 volts and see what happens. If it blows up
it'll make a little crater in the snow but I'm convinced the
protection of the PTC device will not allow that to happen.
As I stated previously, if you move the charging circuit to the cell
itself, the problem of the charger dissapears completely.
I don´t care it it cannot take Lithium or Plutonium batteries. The
point here is that the phone is designed to take a standard
rechargeable battery which will be available forever, and not a
proprietary battery which surely will be non available when the need to
replace it arises.
If you move the charging circuit to the battery pack (like laptops
battery packs do), you don´t have to worry about that.
I said "standard rechargeable batteries", not LiOn. What part of that
didn´t you understood?
And a "new standard" could easilly be established for rechargeable
Lithiums as well. With or without internal protection.
