Rick
Hi guys,
I found a couple of high current pnp darlington transistors (a TIP125 from some
late 1970s circuit board and a new NTE264) and went ahead and built up what I
have so far in a modulated current source for a high power laser diode. Upon
realizing that the only rail to rail op-amp I had in my parts box could only
source/sink about 4mA, I added a 2907 to drive the base of the darlington. The
actual parts that I used are illustrated on this schematic:
http://www.skyko.com/isource/ldcursrc.JPG
I first tested the unit with the NTE264 and a Vin of ~4 volts (for a 2amp
current):
http://www.skyko.com/isource/CONST2AMP.JPG
I then modulated Vin with a 4V 10Khz square wave from a function generator
(channel 1) and measured the current across a ~1.9 ohm resistor as the load
(channel 2):
http://www.skyko.com/isource/NTE264.JPG
I then swapped the NTE264 pnp darlington for the dusty TIP125 and did the same
measurement:
http://www.skyko.com/isource/TIP125.JPG
Here is a pic of Vin modulated with 4V 10Khz (channel 1) with the 1.9 ohm
replaced by 3 chunky diodes in series (to simulate a laser diode voltage drop of
~2.2V). Channel 2 is measuring across all 3 diodes:
http://www.skyko.com/isource/DIODEVOLT.JPG
Here is a pic of the breadboarded circuit (note the output transistor and sense
resistor are soldered to a piece of circuit board to help save the breadboard
http://www.skyko.com/isource/CIRCUIT.JPG
All in all, a pretty good start. If I had some small gate capacitance nfets I
would try replacing Q2 (and possibly Q3) with them. By the way, thanks to Win
Hill and Tony Williams for the hints, tips and circuits.
Rick
current):
(channel 2):
measurement:
Rick
