Hi, I have looked at a solo TV which does not turn on at all once powered. The assembly is of very good quality with multi-layer epoxy PCB. Components selection are also good with well-known brands for the passive. The power supply uses a half-bridge driver from Fairchild semi and I believe it is an active-clamp circuitry. On my board, the 24-V is alive but no reaction to the remote control despite good batteries. I checked all the dc-dc regulators to verify for too high a ripple of an absence of dc voltage, all ok. Finally, I realized there was a TI DSP, a D808K023CPTP4, custom-made for Bose. I remember fixing a Yamaha home theater amp a while back and the DSP was also having problems with an early failure issue. TI had released a service note indicating a replacement part. For the solo TV, it can be the same problem. To identify it, I heated up the DSP for a few tens of seconds - do not fry it if you try, remain below 150 °C - and when I powered up the supply, I could hear the bar chiming and then the remote turned the light on. Injecting music via the RCA did produce a good sound. Then, turning it off several times, it did not restart so this is the issue here also. There are some of these DSPs on eBay but I am not sure if once replaced a firmware needs to be flashed around. Anyway, while the solo was alive, I did successfully update the firmware (connect a USB key while the solo is lit, the drive blinks and it extracts configuration data from the solo, then remove it. Download the program from the Bose website and install it on your PC. Run it and it copies the latest update on the drive. Switch the solo off, insert the drive quickly, turn the solo on again and it did update the bar). I could then successfully restart the bar and enjoy it but I doubt it will last. This is really sad as the system if of good construction : {
