Photodiode wich is fast enough to detect +50Mhz analog (sinus) signal??
Y
Yannick
I am developing a laser distance meter for my Master thesis. I have
problems with finding a photodiode where the junction capactitance is
low enough to detect frequenties higher then 50Mhz(laser diode is
amplitude modulated with these frequentie). The problem is also with
the amplifier after the photodiode, wich amplifier is best for this
purpose? (transconductance amplifier i suppose) i am now doing it with
discrete components (low noise transistors as common emitter or common
basis but still the input impedance is to high to detect such high
frequenties with my current photodiode)
note that the distance is calculated with phase meausurement detection
and not with time of flight measurement of pulses.
any help is very appreciated!
Yannick
John Larkin
Yannick
What's your optical wavelength? 50 MHz isn't especially fast for a PIN
or APD diode detector. An integrated PIN-TIA would be convenient (but
be careful that the AGC doesn't cause phase shift errors) or you could
use a tuned RF amplifier in the front-end to optimize matching and
s/n.
John
W
Winfield Hill
Yannick wrote...
is low enough to detect frequenties higher then 50Mhz (laser diode
is amplitude modulated with these frequentie). The problem is also
with the amplifier after the photodiode, wich amplifier is best for
this purpose? (transconductance amplifier i suppose) i am now doing
it with discrete components (low noise transistors as common emitter
or common basis but still the input impedance is to high to detect
such high frequenties with my current photodiode)
detection and not with time of flight measurement of pulses.
You can take encouragement from the GHz response the optical
networking guys are getting. The secret to high speed is a
small detector size. This also means you must tightly focus
the received light. If you then locate the amplifier right
near the detector, you'll have low total capacitance, which
is the 2nd secret. The 3rd secret is a high-bandwidth opamp,
natch, of course, what'cha expect anyway? The 4th secret is
a low-value transresistance. The 5th secret is a high light
level for good SNR, but perhaps you have a signal-processing
solution to this requirement. 50MHz, no problem.
Thanks,
- Win
(email: use hill_at_rowland-dot-org for now)
colin
Yannick said:
Yannick
at 50mhz the capacitance of any available pd wil be quite low impedance at
50mhz, only way to get it up is to tune it with an inductor.
once you got it tuned at a high impedance its best to use a dual gate mosfet
to make use of the high impedance. watch out for anything that can change
the capacitance or inductance with signal strength, temp etc as this will
alter the phase.
what acuracy, resolution and limits of distance are you hoping to measure ?
im doing a similar thing to see what is posible. limiting problems seem to
be .. the detector amplifier picking up rf interference from the laser
driver, phase change with amplitude cuased by varying distortion in amp
stages in conjunction with ac coupled filters (enourmous variation in signal
strength) . jitter cuased by suden and long term drift in capacitors and
other interference etc, and thermal drift of most things and minute amounts
of light finding a short path back to the detector. oh and not to mention
johnson noise of the estimated 100k input impedance and pd and amplifier
noise.
id be realy interested to see how you do. ive got down to about 15 mm
resolution, any more is realy swamped by drift/jitter wich im trying to get
rid of, although the digital resolution will cope with ridiculosly small
measurments.
Colin =^.^=
John Larkin
Pin pd's are available with sub-pF capacitances and 60 GHz response.
If you load a pin diode with a transimpedance amplifier, the amp's
effective input impedance is very low, so the diode capacitance is
mostly zapped. Agreed, for a narrowband signal, tuning is a good idea,
and it supresses dc (daylight) response.
John
Bill Sloman
Tuning can be a bit risky if you are interested in measuring phase
shifts - the phase shift through a high-Q filter near resonance
changes rapidly with frequency, so any small change in the the
reactive component of any of the filter elements can produce a much
larger change in phase shift near resonance.
Low pass filtering after synchronous detection (ideally, both in-phase
and quadrature) might be better in this context.
Y
Yannick
so i have to put an inductor parallel with the photodiode!?
i was first thinking of using a low load impedance so u still can
measure signals at these frequenties with relative higher junction
capacitance, not?
f = 1/(2*pi*Rload * Cj)
alter the phase.
soo if i get it right, u use a photodiode in parralell with an
inductor too increase the impedance in function of the frequentie and
then u use a high Rload to have a relative high voltage with the very
low current through the photodiode and this voltage u put on the gate
of the mosfet. then u use the drain current to make a voltage(with a
resistor:)) where u do phase measurement with the original oscillator
sinus wave, right?
distance maximum 10m, acuracy as best as possible, i wanted to do
better then 10mm I have made an algoritm wich calculate the distance
when many samples of phase measurements (between 0 and 180 degrees)
are done by different (increasing)frequenties,soo i solved the
ambuguity problem (sorry for my bad english) and it also minimze phase
errors because i compare the ideal triangle wave for every distance
with the measured wave for the distance that has to be calculated, the
best match is the measured distance. it's a kind of fourier
transformation but with triangle waves (because phase measurement
withing intervals of 0 and 180 degrees of increasing frequenties are
triangles in function of the frequentie).
driver,
indeed that problem i also have, i am now seperate transmitter and
receiver completely , this will solve it for now:)
phase change with amplitude caused by varying distortion in amp
noise.
measurments.
thats already good, how do you measure phase difference? i am gonne
use the ad8035 from analog devices. The dual gate mosfet u are using,
can you give the type nr. ?
thanks a lot for the help so far,
Yannick
Y
Yannick
Winfield
i heard about it:)
is the 2nd secret.
why? because the resistance is low due short paths??
ofcourse, do you have a type nr. single suply?
The 4th secret is
50Mhz was to begin with, i want to go much higher as this will improve
resolution.but i first have to get it to work with 50Mhz
thanks for your help
Yannick
Y
Yannick
s/n.
optical wavelengt is 650nm. I fount these avalance photodiodes but
these are quite expensive.(150 euro)
thanks for the help,
Yannick
colin
[/QUOTE]
even 1pf has 3k impedance, wich for a signal of only a few nanoamps does
make for poor sn ratio. reducing the input impedance makes the situation
worse generaly, signal goes up with R johnson noise only goes up with root
R, although this is far from being the only noise source.
i had a good rf transistor as a comon emiter config and just thought of it
as a curent multiplier stage ie pd curent multiplied by hfe (100) and fed
into the colector load. but the noise is far less form the tuned dual gate
config.
yes this is a problem for me i think, the frequency is precise but
variations in capacitances i think are the problem, i think even the pd
curent afects this - not sure, obviously temp does, signal strength too.
maybe it wld be possible to arange several lc elements so it has a wider
passband with minimal phase variance ? wld be tricky, maybe easier at
microwave freq where you cld use pcb tracks as elements .
at the moment cycle to cycle jitter and short term suden changes too is my
problem, longer term drift isnt to much of an issue as if its predictable i
can subtract it, although i might think about resorting to maintaining a
constant temp to ensure temp changes dont afect it. i put a fan close but
the interference from the fan cuased more of a problem. ( i have to remember
to turn of my monitor when i make measurments)
i think its a trade off between noise and phase variance and for me atm im
not sure wich is cuasing the most problem. im no longer sure what to try
next ... i think problem is ive got quite a few stages to fiddle with. its
probably down to needing better capacitors, maybe even my 0.1 uf decoupling
capacitors need to be hi stability types ? .. ive even resorted to stacking
up several SM tantalums in order to get rid of supply noise, soldering one
on top of another ... wich made quite a diference, i can still see 1mv of
ripple at 32khz tho but i think i can ignore this, although im looking for
changes of 10ns in that 32khz signal, jitter from this part seems to be less
than that now.
im wondering if noise iteslf can be considered in the form of varying pahse
shift in components somehow ??
wouldnt you still need some stage of amplification before a detector ? i
have a single stage then fed into a mixer, its not synchronous as i use an
IF to efectivly multiuply length of the phase angle and you still need to
amp the signal quite a bit and at some stage you need to limit the signal
before you finaly measure it as it cld easilay vary by 100db.
tbh i think the limiter is cuasing my problems as the sinewave input to it
doesnt seem to show as much jitter as the output although its hard to tell
just by looking at it on a scope.
maybe synchrounous detection wld be a lot easier. actualy mine looks a lot
like a fm receiver, it just uses a phase discriminator instead of the freq
discriminator ive even used a sa605 fm ic. you wld have to seperate the
signal well from the reference i wld gues or it cld swamp it, or at least
cuase significant error.
could you somehow have an optical mixer ? maybe not at 50mhz but vanes in
front of 2 detectors ...
interestingly my first atempt was to use the light delay as part of the
feedback in an oscilator so the frequency would depend on the distance,
however the change in signal strenght cuased more of an efect on frequency.
this seemed a very simple idea many years ago when i started it, but now its
grown out of proportion, im not the sort to ever give up tho even tho its
driving me mad now ... originaly i thought it would be a good idea to use it
to replace a simple vernier dial gauge, so you could use it on revolving
shafts etc or while you were actualy cuting it, but this was before id
calculated the efects of noise and returned signal strengths etc etc ...
Colin =^.^=
colin
capacitance, not?
the current in the inductor is 180 out of phase with the current in the
capacitor, if you chose the right value inductor it cancels out this curent
in the capacitance exactly and hence your impedance whomps up. you dont need
a resistor anymore , although you might want to tame its Q slightly, say
100k.
f=1/(2*pi*root(LC))
for 30mhz ive got a inductor wound on a plastic toroid (made from 2mm dia
strimmer wire (plastic) bent round a warm soldering iron tip) it has about
30 turns i think (tuned by trial and error by taking off turn untill its
past point of resonance then puting one back on)
i tried a tunable inductor but even with big heavy screens everywhere it
still picked up no end of interference.
sinus wave, right?
yes thats about it. u can use an inductor for the mosfet load too, or a
curent source, or a higher voltage and a plain old resistor. if you tune the
input and the output too much you are prone to oscilation, and of course
phase variance, its just one big trade off noise/amplification/filtering
versus phase variance. lots of playing around unless your expert at
mathmatical modelng.
of course with 10m your going to have more than one cycle of delay with
50mhz, and so you measurment will overflow, good luck with 10mm resolution.
returned signal strenght at 10m is going to be oh so low, you wld need i
think an APD and not to forget a good lense, and a white target.
i gues you would need to be sure your signals are the precise shape you
calculate for. this isnt easy with hi frequency non sinewaves. maybe trial
and error and some calibration might be required.
i have two 30mhz signals (32khz apart) going into an xor gate and the signal
that comes out looks awfull after the first low pass filter.
you need to screen things well and seperate power supplys ( of course) and
also carefull ground planes. if you seperate them to far u then have long
signal wires wich can also be problomatic. also your beam has to travel down
the center of your line of sight of the PD if you use a lense.
wel i cheat a bit at the moment im using a hp 5328 timer counter, wich has
sub picosecond average time interval measuring, however i use frequency
shifting to lower the frequency down to 32 khz, but keeping the same phase
angle so i can multiply the delay by 1000 or even much more, so i only need
to measure down to 10ns wich u can easily get modules to measure that, or
even just measure the average dc level of the pulse from the edge detector.
i might even put an on board micro although doubt il have enough enthusiasm
left to do that for a while, not sure if it is easy enought to get this to
the stage where it could be a viable comercial product, do any such exist ?
ive heard of some devices wich use multiple receivers at diferent focus
points/angles to detect distance.
the variable bandwidth with amplitude could be an issue if you use this
device before the synchrounous detector.
im using a 5mw red laser, a ca3209 APD fed into a bf998 dual gate mosfet
wich is fed into a an emiter folower and a PIN agc circuit wich goes into a
sa605 fm mixer ic although im thinking this is cuasing some problems at the
moment. i might go back to the string of ecl diferential amplifiers i used
before.
the delay cuased by varying the gain with the PIN is fortunatly in the
opesoite direction to the rest of the circuit, ie stronger signal means
longer delay, but more atenuation actualy means less delay, unfortunatly its
hard to get the two to cancel perfectly, but i live in hope.
i might up the main frequency but first i need to find another two crystals
that are 32khz apart wich is dificult. i might change the 32khz to 455khz
and use proper IF filters rather than made from discrete wich i think is
cuasing a problem, or even have 2 IF frequencies or even lower the frequency
still further say 100hz then just do low pass filtering, but then wld need
virtualy dc coupled stages.
I had hoped to use a 32khz crystal as a IF filter but this wasnt very good
for phase variance, although jitter was non existant. .. sigh..
unfortunatly i cldnt get 455khz filters from RS or farnell, does anyone know
where i can get them easily in the UK?
i think you have a very chalenging project. good luck and keep me posted
please :)
sory if my english is hard to understand at times too, i have no real excuse
for it tho.
Colin =^.^=
W
Winfield Hill
colin wrote...
root R, although this is far from being the only noise source.
Careful, using a sufficiently-wideband opamp can insure the summing-
junction impedance will be low compared to the total shunt capacitance.
Resistors have 0.05pF to 0.1pF of self capacitance, this should be your
total feedback capacitance. With 3k resistor you'd have a -3dB rolloff
at 530MHz. You want high R for low noise, so we'll try 100k, yielding
a 16MHz rolloff. Then we can apply the standard R-C-R trick (this is
more than 30 years old) to get a flat frequency response to 75MHz, or
whatever you decide your bandwidth should be.
The noise density from 100k will be sgrt(4kT/R) = 0.4 pA/rt-Hz, which
is 3.5nA rms for a 50MHz -3dB bandwidth (applying the pi/2 brickwall
correction, see AoE p 453). But the unavoidable "e_n - omega - Cin"
noise will be higher, see any of my many posts about this subject.
For example, if the opamp's e_n = 6 nV (for an opa655) and Cin = 5 pF,
the e_n-C noise density will be 1.5 nA/rt-Hz at 50MHz, exceeding the
resistor's Johnson noise. Moreover, since e_n-C noise density rises
with f, you'll want to consider a sharp band-limiting filter.
It may be necessary to use a composite amplifier configuration inside
the loop, to insure that the gain meets f_T > 2pi Rf Cin fc^2 = 8 GHz.
This may seem a bit daunting, but it's actually rather simple. R2 is
adjustable, to compensate for the unknown value of Cf (you'll need an
accurate input-current step to adjust R2, but that's another story).
| Rf R2 adjustable
| | '--||--' | C2 R3 | nA-sensitivity wideband
| | Cf '--||--/\/\-- gnd | transresistance amplifier
| | __ ,-||--/\/\--+ correction network details
| input O--+---|+ \ | __ | R2 C2 = Rf Cf
| | >-+-/\/\-+-|- \ | R3 C2 sets bandwidth
| ,-|-_/ | | >-----+---
| | | gnd --|+_/
| gnd --/\/\--+-/\/\--' composite amplifier
With proper component selection you may use de-compensated opamps. For
example the opa657 has an open-loop gain of 30 at 50MHz. This amp has
slightly lower noise than the opa655, but higher capacitance.
You may want to consider a BJT opamp, but these have high bias currents,
and therefore have high input shot noise currents. For example, the 1GHz
bandwidth ad8009 has an input current-noise density of 41 pA/rt-Hz, which
greatly exceeds the 0.4 pA noise we saw for our 100k feedback resistor.
config.
No, sorry, faulty reasoning, go back and read / study some more.
Thanks,
- Win
John Larkin
Yannick
At 650, you could probably use one of those Agilent integrated pin-amp
ICs. They are intended for fiber-optic receivers, but you can just
focus light on the chip anyhow. They are very cheap.
Otherwise, a cheap silicon pin diode should work; see Tyco, OSI,
PD-LD, Laserdiode.com, people like that.
John
Mike
No... As Win said, the total capacitance is low. The resistance is low too,
but at 50MHz, the capacitance will tend to dominate in most cases -
especially if you place the amplifier near the detector.
-- Mike --
Y
Yannick
100k.
f=1/(2*pi*root(LC))
yes ofcourse, Z = (l/C)/(1/jwc + jwl) , Z to infinite so 1/jwc + jwl =
0 => w = 1/root(LC)
the problem is the phase will change very rapid with an increase in
frequentie , so i don't think i can do this because i am doing
multiple measurements with different frequenties, soo i have to know
exactly what the phase difference will be at every frequentie but this
wont be easy when you do 100 meausrements orso.
yes thats why i use multiple measurements with different frequenties
hehe thanks:)
my signal is a sinus, the triangle waves i talked about is not the
signal but the shape of the samples (between 0 and 180 degree) in
function of the frequentie (of the signal : sinus).
i see you mix the HF signal with a HF signal + 32Khz,then you get an
32Khz signal with the same phase difference... looks interesting.
micro?? what do you mean?
before.
i wish you luck
i am thinking about using a DDS frequentie synthesiser , Analog
devices have 2 chips , one too 60Mhz and one to 400Mhz. with very high
resolution
please :)
thanks, i will
for it tho.
nono your english is perfect!
W
Winfield Hill
Steve Parus wrote...
They say very low noise, 2.8dB, but that's with a 50-ohm
source impedance, right? If so, that's actually a HIGH
noise, about 16 pA/rt-Hz, 120nA rms over a 50MHz bandwidth,
compared to a 0.4 to 1.5pA/rt-Hz, 10nA rms noise level for
the amplifier I described yesterday.
Thanks,
- Win
Y
Yannick
colin said:
ah i see i didnt realise you were needing to use multiple frequencies to do
this. sounds like a good idea. but does tend to rule out a tuned stage,
unless you fancy trying to use two lc networks acros the pd wich i beleive
might give you two equaly well tuned points for 2 diferent frequencies. bit
the same as the equivalent circuit of a crystal wich has several harmonics.
but considering tunable inductors tend to be susceptable to emi pickup i
wldnt fancy doing this, although you could use a variable C in series with
the L, in fact i might try doing that with a single L anyway.
yes that's a point but only if u use 2 frequenties,then you will do
like u said , first a low frequentie to detect in wich period our
signal will be and then a higher frequentie to know where we are in
this particulary period(soo we got high resolution) but the problem is
that we only can do phase measurement within 0 and 180 degree, soo you
cant really see in wich half of the period we are measuring, thats why
u need at least three measurements...
i maybe will use 100 different frequenties, for example i start with
50Mhz, then 51MHZ, then 52 and so on. then consider the distanced you
measure a constant , and plot the phase difference between the sended
signal and the received signal , you will see this will be a triangle
wave (waving between 0 and 180 degrees) in function of the
sendfrequentie. if you compare this wave (the wave with the received
phase measurements) with the ideal wave, you can calculate wich is the
right distance.(for every sample do : positive Root[(measured phase -
calculated (ideal) phase)^2] then make the sum of it(yes indeed its
like a fourier transformation but with triangle waves in stead of
sinuses) the more samples you get the better your accuracy will be and
noise will have less influence.
as i said i thought of many ways of doing it, there are quite a few
posibilities. i was a bit limited to using what i cld find to start with,
its pretty limited what u can do with ordinary photodiodes and leds. some
time ago i was lucky enough to have a scrap fiber optic transceiver from
wich i used the discrete transmiter and detector. now ive progresed to using
a 5mw laser and an apd.
it wld be interesting to try and use frequencies up to ghz maybe use some of
the many ics made for cell phones etc.
yes indeed the higher the freqeuntie the better our resolution will
be. but its hard to detect such high frequenties.
a small microprocessor, wld be usefull becuase then i cld use a programable
frequency synthesizer to generate the various difernt clocks i need, rather
than doing it with discrete PLL, mixers etc, and also use it for calibrating
it.
indeed ofcourse that's also my plan. I am gonne program an atmel
AT90S8535 microcontroller to send the signals to a DDS frequentie
synthesiser wich gives the right frequenties in a minimum of time. the
only problem with the analog device DDS synth is that the main clock
is 120 Mhz soo when u want 60Mhz out you only get 2 samples , then
after DA conversion thiss will make a square wave, and then u have to
use antiimage filters to make a sinus again. but i am not sure how
good this will be, what kind of DDS frequentie synthesiser will u be
using?
it's good someonse is also trying this challenge, gives me hope :),
greetings,
Yannick
Y
Yannick
hmm this is very interesting way of doing it, in fact if you cycled through
a frequency range wouldnt you then get a phase change that varied with a
rate of change equal to rate of frequency change x distance, then you cld
convert this to a frequency wich is proportional to distance ... and use a
simple freq counter.
indeed that's another way of calculating the distance out of the
triangle wave but how would you measure its frequenty ? then you
should again do DA conversion and filtering and then put this signal
into a frequenty counter, or do i completly miss the point here?
yes the signal to noise ratio gets worse thanks to the capacitance, unless
you tune it, but i think you would only need such high resolution over
shorter distances where returned signal shld be stronger anyway. using realy
high frequencies would only be of benefit if returned signal was so strong
you didnt need to wory about s/n ratio.
yes thats right.
my main area of aplication would be
in acurate positional sensing for use in robotics, machining etc. althogh
distances may be short the surface might be reflective and reflect most of
the light away.
ok, what kind of lense system are you using to detect the light? did
you bought a module or made your own one?
as a further thought i may try using a frequency multiplier after the tuned
input stage so i cld select the fundamental or 3rd or even 5th harmionic
easily just by simply changing the LO frequency, wich wld give me 3 ranges,
and just have a 10mhz signal.
hmm that's clever.
converting the square wavr to sine might mean you get variable phase shift
with filters, dont know about antiimage filters, but u cld either use
triangles and a very simple triangle to sine converter or use lower
frequencies and then use a mixer to generate the higher frequency.
yes but i think i am going to use an elleptical filter with 47Mhz cut
off frequenty like Analog devices is using on their evaluation board
for the DDS.
a micro wld also be usefull to drive a 7seg led readout or even a LCD
display.
yes ofcourse ,and the atmel AT90s8535 does have a 10 bit AD convertor
soo this is also usefull.
I also had a different idea last week about doing this project :
nothing more with phase calculation of sinusoidal signals but just
with pulses:
you send a very short puls , simultaniously you start charging a
capacitor with a current source (soo it charges lineair). When the
reflected pulse arrives on the detector you sample the voltage across
the capacitor and this is in direct proportion with the distance the
photons of the laser travelled. u should use a very fast SR flipflop
(to start charging and uncharging the capacitor) and a low noise
current source , and a high bit AD convertor, this should do the
trick. What do you about this?
Yannick
