Sadlercomfort
Ash
Here it is complete.
Looks great! is it some form of radio?
More work...
just beware tho, in that latest board, you are still getting very close almost connections between lands and tracks that could lead to faults
Good job Constantine! Looks like you snuck in those smd's just fine. You should put these pics up on your project post too for all to follow with an updated schematic. I hope it works better now!Here are pictures of the new Picaxe project board.
Thanks. I will upload an other pic when PCB is populated and ready to use.Great Job!
thank you for being kind !That board looks really good Constantine!.
I only see one trace that got necked down and needs rework.
The only way I have found useful to counter that is to take away as little copper as possible to form the traces and leaving the rest on the board.
This may not be electrically acceptable in some cases, but for common circuits it should be ok.
I have found the opposite - if the solution is weak, it takes too long to etch everywhere evenly, leading to undercutting and pitting. A stronger solution in my recent experiences has successfully etched small boards (under 2"x2") in about 7 minutes. Warm solution works better. Having a denser toner transfer is crucial too, that is why I am interested in the photo method - I think that film will be more resilient and produce a cleaner etch.I agree. That you can do by useing a not too strong solution
