PCB building
IMG20150430_001.jpg IMG20150430_002.jpg IMG20150430_003.jpg IMG20150430_004.jpg IMG20150430_005.jpg IMG20150430_006.jpg Here are Pictures of my latest job.
Tommorow i am going to make a new PCB to demonstrate you what i can make in much more detail.
The board you see here has not been perforated or coated.
The white stripe is where my last name is printed on the board.
IMG20150508_001.jpg IMG20150508_002.jpg IMG20150508_003.jpg IMG20150508_004.jpg IMG20150508_005.jpg IMG20150508_006.jpg IMG20150508_007.jpg IMG20150508_008.jpg IMG20150508_011.jpg 004.jpg This is an other sample of my work.
the white box is where my first and last name are on the board.
Thank you very much.
HellasTechn
Where are you based, I might be interested in having some PCB developed. I have a light box and that but haven't done it for a long time.
Jason
Greetings,
I live in Greece.
I see you live in the U.K. is that correct ?
If yes and in case you decide to order PCB then you should know that shipping to the U.K. is easy and should take no more than 7 to 10 days also note that i always ship packages registered so i will provide you with tracking number.
Please feel free to ask anything you need.
Thank you for your interest in my work.
PCB top side.
Coming up next : PCB with SMD components and Solder Mask.
I will delay that a bit because i will be away for a week or so.
This is a sample of my work involving SMT components and Solder Mask.
The PCB's dimensions are as follows.
PCB: 70mm X 100mm (2.75 inch X 3.93 inch)
Trace width: 0.51mm (0,020 inch)
Clearance around traces and pads: 0.71mm (0.028 inch)
This board here is etched and sanded with extra fine sandpaper as part of soldermask preparation.
Traces are 0.51mm wide and clearance around traces and pads is 0.71mm.
Board dimensions are 70mm X 40mm.
Good technique Constantine!!!
20 thou trace width by hand is very, very good! Kudos. Especially when you have a hole through the trace, that is an easy area for over etching. This is a very clean board, bravo.
Here is the above PCB with solder mask.
Here traces are 0.38mm wide (0.015 inch) and clearance around traces and pads is 0.50mm (0,020 inch). Letters are of same size.
Well i beleave the quarter is the coin that most people have held in their hand at least once in their lifetime so that makes it easyer to compare size. About usefullness well currency in general is as valuable as we say it is right?
"i got your joke though":)
This board was ordered by Sadlercomfort which i thank.
