I'm trying to troubleshoot a control board failure. You can see in the picture the board, where a connection was burned and melted some of the plastic. The orange wire there connects to the oven heating element. I checked the heating element and there's still continuity. The stove top, clock, convection fan all still work. I have no problem replacing the control board myself, but i've got a couple questions before i do.
Anyone know the likely cause of this? If it's more than just the control board, i'm not sure i would repair it so i wanted to see if there are other things i should check.
Do i need the white plastic part around the wires, or can i just cut it and put new connections on? Only the left and right posts are connected to wires, so there's space in between. Should i put tape over them after i attach the wire? Otherwise, i'm not sure where to get the plastic wire holder and frigidaire only sells full wire harnesses but i can't even find this one on their site.
