Platforms
Content
Thank you very much,Here is the video of the voltage measurements on the transformer: (1.5 minutes)
you can send me scanned data sheet at email please,
Thanks one more and have a nice day.
O I did not see you already post picture, thanks they are all good visible,
I appreciate you hard work, Thanks
wowww. I have searched for some information about fixing my oven and finally I reached here and got everything I need. This site is an example of mutual cooperation to make the world better. Thank you all...Replaced transformer (Open Primary winding) with a Tamura xfmer manuf part number 3FS-212 $5.45 from Digikey and it has been working fine. Which means Triad Magnetics F12-090-C2 or Hammond Manufacturing 164D12 will also work. Because capXon capacitors were on the board I replaced the two 16V 100uF caps with nichicon UPW1C101MED. Replaced the 25V 1000uF cap with Cornell Dubilier Electronics (CDE) / SEK102M025ST. The kicker in getting a 6.3v parallel / 12.6 V series xfmr was the thumbrule that the voltage rating of a filter capacitor on a full wave bridge should be at least twice the voltage. 25/2 = 12.5V, also the must operate voltage on the 12 volt relays were 9.0 volts and 9.3 volts on the manufacturer spec sheets. In hindsight I could of bumped up the voltage rating on the 1000uF cap when I ordered parts. I also ordered VARISTOR 430V 2.5KA DISC 10MM, TDKElectronics Inc. / B72210S0271K101 (the blue thing) but did not replace. An extra 50 cent cost is nothing if I didn't order it and later found out I needed it. I would have to reorder it, pay the 9 bucks or whatever minimum shipping is and then have to wait for the part. Hope this helps. Now go fix your board! Tim
