Hmmm. I wonder what $5000 per bin buys these days? That sort of cost reminds me of the 1960s. This is a DIY site you are posting on, so why not try a few experiments to see if you can produce acceptable results and get the cost down to, say, $50 per bin?
Strain gauges are inexpensive (in many applications they are disposable) but they are also fragile until cemented in place, usually with a
cyanoacrylate adhesive (super glue) and then coated with a
protective rubber sealant. Wire connections to individual strain gauges require a small intermediate terminal strip, similar in size to the strain gauges, that serves as a strain relief when the data cable is attached. This terminal strip is mounted close to the strain gauges using cyanoacrylate adhesive and covered with a protective rubber sealant after the data cables are soldered to the terminals and thin wire connections are soldered to the strain gauges.
All this messing around with strain gauges is a lot of work, so it may be desirable to make your own "L"-shaped transducers for attachment to silo support legs. Or, you can purchase an
inexpensive load cell for about ten bux, bolt it firmly to one leg of your silo, and then see how much its output changes as you empty a grain silo. Or wait until a silo is empty, and see how much the load cell output changes as the silo is filled.
This is where experimentation comes in because using strap-on (or bolt-on) load cells will not be nearly as sensitive as placing load cells on the ground directly under the silo supports, or attaching strain gauges directly to the silo support legs.
Some signal-conditioning electronics could be installed at the strain gauge sites, with shielded cables carrying amplified strain gauge signals to an Arduino with its 8-bit analog-to-digital converter interfaced to a laptop computer. Other microprocessors, as well as more bits of A-to-D conversion, are also possible. The important thing is to get the raw analog strain-gauge signals digitized in a format that is presentable to the laptop computer, which will do all the "heavy lifting" of displaying the results and selecting which silo weight to display.
Many other configurations are possible of course, but assuming a laptop is available the cost for readout instrumentation should be less than $100 for as many silos as you wish, since you only need to measure the weight of one silo at a time. Um... be prepared to write some software, but keep it simple. No need for fancy colored bar-graph displays. Also no need for a Wi-Fi network to get data from the silos... cable is inexpensive and much less sensitive to RF signal loss and interference.
If all this seems to be more than you care to get involved with, your climbing robot with a solenoid-activated striker and a sensitive microphone to "listen" for the response could be your best bet. How would that climbing puppy work? Magnetic treads to grip the side of the silo? Might need some fancy on-board audio processing software to make sense of the "echo" after banging on the side of the silo, but it appears to be a "do-able" solution.
