martin griffith
Found this, maybe of interest to audio dudes here
http://lavryengineering.com/forum_images/Condenser.pdf
martin
martin
martin said:Found this, maybe of interest to audio dudes here
I imagine that the effect is real, but there is way of using negative
feedback to get around it.
The author should have read up on the subject before publishing his
simplistic and unrealistic (10% capacitance variation!)......
One could feed the capacitive mike into a short circuit (summingmartin said:Found this, maybe of interest to audio dudes here
martin
Genome said:This is rubbish because the measurement sytem does not take account of the break up of the bits.
martin
Tanks for your eloquent expansion of my suggestion.Pieter said:The linearity changes with capacitance change. The capacitance does
not change when the voltage does not change. So to prevent voltage
changes!
To do this, the microphone must be short-circuited (can also be into a
DC offset). The way to do this is feed the signal into the - input of
an opamp that has capacitive feedback. This way this circuit does not
function as voltage amplifier, but as CHARGE amplifier. The charge the
sound delivers is amplified.
I designed an accelerationmeter based on a crystal device (capacitive)
that had a very large frequency range this way.
Another advantage is that the signal is very low-impedant, this means
low disturbances, low noise. And it is not sensitive to the length of
the cable (the cable only sees a short-circuit), and it isn't
sensitive to movement of the cable.
Feel free to ask any questions.
Pieter
email: [email protected] without the NOSPAM
changes!
This statement is simply incorrect. It is also incorrect in a complex way
too but we'll ignore this for now.
Actually, it is more likely to act as a slightly charge sensitive RF
oscillator with a lot of noise.
No, it means very high noise. The input noise voltage of the op-amp
divided by the impedance gives a noise current. Also the lower a resistor
is, the more its noise current. When it comes to noise, you can't win,
you can't break even and you can't get out of the game.
Try tapping on a coax with a little bias voltage on it connected to such a
circuit. You will find that the circuit is sensitive to moving the cable.
I've had to shock mount cables.
If a train is leaving the station at 11 miles per hour ..........
[...]Actually, it is more likely to act as a slightly charge sensitive RF
Not when you do a proper design. The opamp is feedback capacitive,
making it very stable. A small series resistor at the input may be
wise.
Low sensitivity to outside disturbance.
The other circuits are sensitive. The one is decribe here isnt. When
then is a short-circuit, there is no voltage. Where there is no
voltage, that voltage can't change either.
But it is best not to use
phantom feeding, but a separate power supply cable. The phantom's
voltage does interfere.
Ken said:Pieter said:[...]
wise.
Putting a feedback capacitor on a high performance op-amp does not make it
"very stable". You have to use a "unity gain stable" one in this sort of
application. Without the small resistor you suggest, the op-amp is fairly
likely to oscillate even if it is a "unity gain stable" one if the input
cable is very long. The cable and capacitor look like a tuned circuit.
No, this is not the case. The circuit you suggest is this:
Noise
---Cnoise
! A -------------
Signal -[Zgen]---+-------! Z Amplifier !---- GND
You can't improve the signal to noise at "A" by making Zamplifier low.
How ever much you lower the amplifiers input impedance, you must also
raise its voltage gain by too to maintain the same signal output.
Just for fun, lets assume that Zgen=Cnoise and the Signal(RMS) is equal
to the noise(RMS).
High Z amplifier case: SNR = 1:1
Low Z amplifier case: SNR = 1:1
When there's no impedance, the current is infnite and thus the noise is
infinite. It was exactly the sort of circuit you are suggesting that
required the shock mounting of cables.
Try tapping of a length of COAX even with "no voltage" on it. You will
still see spikes when you strike it. Just hook a BNC-BNC cable onto your
scope's input and wack it against the work bench.
Ken Smith wrote: [....]Try tapping of a length of COAX even with "no voltage" on it. You will
that it does. unless its terminated.
I didnt do a very good job, but I tried to isolate both connector ends,
and only whack the middle. simply waving an end about picked up a lot if
noise. my crude attempt at isolation greatly reduce the resultant spike.
its extremely sensitive at the connector.
I wonder if its because the open end is moving thru an otherwise
stationary E field. so I wrap it in tin foil, and it makes no difference....
so whats going on here? is it simply VdC/dt, with dC/dt due to the
pressure wave propagating thru the cable?
If you hit it hard enough, you get triboelectric effects. This is the
voltage generated when you mechanically break most materials. At lower
hits, I believe, it is charges trapped in the plastic materials that is
doing it. At the terminated end, the parts can move with respect to each
other more easily.
Not just triboelectric effects, piezoelectric effects as well.Terry said:Ken said:Terry Given <[email protected]> said:Ken Smith wrote:
your scope's input and wack it against the work bench.
difference....
other more easily.
makes sense. same reason semiconductor physics tests all assume an
un-stressed material.
Cheers
Terry
difference....
other more easily.
Cheers
Terry
Picocoulomb/g accelerometer sensors require very special cables which
require very special connectors in turn. I have had to use these and
special microwave cables (vibration resistant) when testing waveguide relay
switches under vibration. I think i still have a made-up cable somewhere.
The tooling for terminating such an accelerometer cable is probably in
excess of US$10,000 by now, 20 years ago the cable was US$20/ft.
