OT: Wheeeeee! New PSpice Benchmarks
Mike Engelhardt
What clone? Whose clone.
I'm not allowed to talk yet until the official
release, but it has a PSpice Schematics lool-
alike for the frontend, plus can handle
device-size library binning which PSpice can't
do.
LTspice has had binning for years. It lets you
mix hspice foundry models with PSpice behavioral
syntax. Folks have been upgrading from hspice
and PSpice to LTspice for years.
--Mike
K
Kevin Aylward
Active8 said:
On Mon, 23 Aug 2004 20:48:00 GMT, Kevin Aylward wrote:
I hate it when good things dissapear or obviously useful things just
aren't implemented. So all Orcad will be good for is Layout. plbht.
What's library binning?
Binning is when there are a range of models that cover ranges of sizes.
e.g.
..model model_test.1 nmos(lmax=1u, lmin=1u wmax=1u wmin=1u)
..model model_test.2 nmos(lmax=1u, lmin=1u wmax=5u wmin=2u)
..model model_test.3 nmos(lmax=10u, lmin=3u wmax=5u wmin=2u)
etc...
The software looks at all the models with the same extension, and picks
the one that satisfies the schematic sizes. As noted, SS supports this
feature. Its actually a bit more complicated, as ech model has 3
versions strong, weak and nominal. When SS does worst case, it
automaticaly selects the correct wc model and bin. If a wc model dosnt
exist, it uses typical default wc models.
Kevin Aylward
[email protected]
http://www.anasoft.co.uk
SuperSpice, a very affordable Mixed-Mode
Windows Simulator with Schematic Capture,
Waveform Display, FFT's and Filter Design.
K
Kevin Aylward
Ken said:
They are behind on the technology eventually the public may figure it
out and start switching.
No chance. "He who is first, wins".
Harvard, coke, kellogs, birds eye etc...
Kevin Aylward
[email protected]
F
/* frank */
Dopo dura riflessione, Jim Thompson ha scritto :
2.175 times faster !!!
Faster time - surely - isn't due to 64 bit:
nor WinXP neither pspice.exe are 64 bit ;)
Jim Thompson
Active8 wrote: [snip]
e.g.
etc...
Kevin Aylward
[snip]
While PSpice doesn't internally support binning, my oldest son wrote a
tool for me that automatically processes the netlist to accomplish
binning.
Nice to have a C++ expert in the family! Unfortunately he's so good
that he recently became software kingpin at the largest
call-center/telemarketing organization in the US :-(
...Jim Thompson
Active8
e.g.
etc...
Kevin Aylward
[snip]
binning.
...Jim Thompson
Who would that be, Convergys? Just a guess.
K
Ken Smith
You may be wrong. A 64 bit bus can transfer more instructions per cycle
and move a "double" in one stroke. Since the software has to do a lot of
both, it could be the 64 bit nature of the machine that helped to gain the
speed.
It could also be like the new navigation system we just installed. They
got a 25% increase in performance just by changing to a synthetic oil on
the relative bearings.
Jim Thompson
On Tue, 24 Aug 2004 07:46:25 -0700, Jim Thompson wrote:
[snip]
binning.
...Jim Thompson
Phase2
...Jim Thompson
K
Keith Williams
speed.
Even the lowly Pentium-1 (P5) had a 64bit bus. Memory can only be
referenced a cache-line/sector at a time. You want one bit? You're
getting 255 more where that one came from. ;-)
The difference is quite likely do to the integrated DRAM controllers on
the Athlon64/Opteron. The memory latency is significantly less than it
would be with a northbridge attached memory system.
John Larkin
Another one lost to The Dark Side.
John
Jim Thompson
John
But he's a good source of information about the legalities of
telemarketing.
Unfortunately most of the telemarketers don't follow the rules. My
son's company does, enforced by his software that forces no dialing
followed by a hangup.
My son advises talking to telemarketers to determine who they are,
then file a complaint.
...Jim Thompson
Andreas Hadler
Spehro Pefhany said:
On Tue, 24 Aug 2004 13:10:26 -0700, the renowned John Larkin
Which dark side, telemarketing or C++?
I don't consider C++ as dark side, it's just that C++ calls for the
dark side of programmers. It's not the gun, that's evils - it may be
the one who uses the gun.
Andreas
Active8
telemarketing.
You mean no dialing following a hangup. Prob is that some companies
who *do* follow the rules have customers who want them to schedule a
callback if they don't get the whole pitch out, otherwise "not
interested" means just that. I'm in a no rebuttal state so "not
interested" is supposed to end the call no matter what, but
sometimes they'll ask a question. Sometimes the telejock will get
pissed off and sched it for a few minutes later.
...Jim Thompson
Maybe it's at inetjunkbusters.com... there's a script you read to
the telejock to get the info you need and f*ck up the whole call for
him/her. It's funny, really.
I'm on the PA DNC list, but Verizon, Sprint, etc. with whom I do biz
can still call until I ask to go on their DNC list.
You can also google TCPA for the fed laws. Telecommunications
Consumer Protection Act.
BTW, Convergys... bad guess. They do outsourced tech support, not
telejockery. Hmm... telejocularity, it's been.
Spehro Pefhany
I think the first way was correct. A lot of the telemarketers have
machines that autodial more calls than their people can handle. If you
pick it up and the machine reconizes a "Hello" there is a slight delay
while it transfers the call to a human or a hangup if there is no
human available. I generally use that opportunity to hang up myself,
as real people always answer a "hello" very quickly. The message on
our home answering machine is short enough that it is often mistaken
by the calling machine for a human answering, so it tends to waste
their time (and it's a one touch delete). There's one charity that
leaves the same message every month "hello?", "hello?" .... "click".
Sometimes *two* machines will go one for a minute or more talking to
each other. Some companies have implemented automated questionaires
with their (soon to be former) customers.
Best regards,
Spehro Pefhany
Jim Thompson
[snip]
So does Phase2. They were also capable of completely taking over the
telephone operator's functions when they went on strike a few months
back. So seamlessly that it wasn't even noticed by the customers...
there wasn't even a few seconds of dead time.
...Jim Thompson
Active8
[snip]
...Jim Thompson
Oooh.. bet that cost the telco. But they'll get it back by
overcharging everyone a few pennies here and there, just like they
do to recoupe lost revs from fraud.
Rich Grise
Active, I'm disappointed in you. Howcome you're not ragging on Mr.
Thompson for having a favorite son who's a professional annoyer?
Cheers!
Rich
