Platforms
Content
But it won't make a machine gun noise![]()
They could have been his. ;-)
From the noises you reported, very probably yes. But it couldn't do anyJoerg said:Just wanted to know whether this is a fuggetaboutit situation by
default, like a blown cylinder head on a 15 year old car would usually be.
Jim said:I could sleep in the same room with the Miele running full tilt, and
I'm a very light sleeper.
Paul said:If it still agitates, its probably the fwd/reverse cam. Either something
came loose or broke.
On my washer, the pump always spins. For agitate, it spins in the direction
to pump water into the basin (which does nothing). For the drain direction,
the pump turns in the direction to drain the basin.
If the pump were seized, the belt would slip in either direction.
Jim said:PerhapsThe ones I've seen have drawers for detergent, etc.
They actually look rather nice (my pick-em-up truck is very RED ;-)
My concern is how well do the seals required by the front-loading hold
up over time.
We ordered sans pedestal. I think a washer on a pedestal looks tacky. If
we can't bend down to do the laundry anymore some day in the (hopefully
very) distant future we either move to assisted living or hire it out.
I wouldn't care one bit about the color or whether it matches the dryer.
But I am married, so ...
Ayup!
I grew up with front loaders. Never ever saw one of those seal go bad.
What dies sometimes is the drain pump, or it gets clogged. Often front
loaders have a small lower panel that comes off and they place the pumps
right behind that. So not major teardown and disconnect like with top
loaders. Sort of an "outpatient treatment"![]()
Nice surprise: We'll get a $50 rebate via our electricity bill for
buying an Energy Star rated front loader. Yay. One night of Sushi will
be almost free now.
Rich said:From the noises you reported, very probably yes. But it couldn't do any
harm to pull it out from the wall, take the back panel off, and take
a look.
Don't know about a pedestal, but I wouldn't mind stacking them.
The problem with front loaders is the main bearing. They have a *horrible*
track record. I thought I was getting around that problem with the Whirlpool
Cabrio, agitatorless top-loader. Nope, they have serious problems too. I
hope ours lasts another year or so, but I doubt it will.
Stealing from the neighbors, again... ;-)
Joel said:Just as a point of reference, back in the ballpark of 2000 I had a
frontloader I had bought used (it was likely already 10 years old), and
its front seal failed... although it did so gradually, so in the
beginning there were only small puddles on the floor.
Although come to think of it... it had begun to make a LOT of rack while
it would spin up or slow down. That probably was the bearings, eh?
Not possible, we have hanging cabinets (fixed) and a window.
Can't say that. In Europe that's the only kind of washer there is and
I've never had a bearing go out on me.
The drain pump on occasion but
that's an easy and fairly cheap repair. Then maybe a new belt every 10
years, not quite that easy but can be done in an hour, usually. I mean,
what's that bearing have to hold in comparison to the front tires on
your car? 30lbs of wet laundry, plus a little spin imbalance, plus maybe
40lbs for the drum? And the bearings I've seen where similar in size.
No, this is my first one in years, after getting a $25 or whatever
rebate for a low-flow toilet that usually needs more water than the old
one because of double and triple flushing
Seriously, neither they nor the tax authorities seem to have the
foggiest about real energy savings. The evap cooler I installed last
year dropped the consumption for that purpose from a whopping 7kW to
0.4kW. Any rebate or tax advantage? Nope. Nada.
[email protected] said:[...]
up over time.
In case you hadn't noticed, this isn't Urup. The manufacturers have cut them
to the bone, and beyond, evidently. Do a web search on various models.
Well, we ordered a Maytag 2000 series, just discontinued so we got a
deal. I don't like the new roundish designs anyhow. At least it's a good
brand although the fact that they already purged the model from their
web site doesn't come across as very professional.
Their typical tub bearing prices seem to be around $20-30. I usually
check that stuff before a purchase.
But that's the same on a car going across a bumpy road. Which in the
currents state of affairs most roads are. Plus the slightest curve
creates lots of off-axis load.
So why don't they just tear down a Miele, Siemens or Bauknecht and see
how they dunnit? Those don't break down.
I agree that there shouldn't be. But if there is then at least they
should get them prioritized right.
Probably cheaper than a repairman!Joerg said:Took the easy road, to the Sears Hometown store a couple miles from
here, and ordered a new washer![]()
Joel said:I kinda figured the pedestrals were for older folks so that they don't
have to bend over quite so far?
As for red... I suppose beauty is in the eye of the beholder there!
No, they are great. We had them in Europe where those agitator washers
went obsolete in the 50's. Yes, the wash cycle takes longer, uses less
water and energy. But with shirts you see a major difference. After
20-30 washes you can't wear it to a fancy board meeting anymore. In
Europe that never happened, the collars and all didn't wear off at all.
You could essentially wear it until out of style (my wife needed to tell
me when that was ...). A lot of things that would instantly tear up in a
top loader can often safely cycle through a front loader. Meaning less
hand washing.
Problem is, I know the brands from way back over there but not LG and
all those that we have now. Like this one:
http://www.homedepot.com/Appliances...d=10051&catalogId=10053&superSkuId=202705384#
Jim said:Front loaders are so... so... so Obama green, and lousy washers :-(
And all those extra seals... all made in China![]()
Joerg said:But it won't make a machine gun noise![]()
Hello,
the font loaders I used in the last 30 years never had problems with the
extra seals needed for a front loader and they were good washers. What's
the problem if a washing maschine uses less water and less energy if the
laundry is clean?
Well, we ordered a Maytag 2000 series, just discontinued so we got a[email protected] wrote:
Jim Thompson wrote: [...]
up over time.
That may be, but it's a $700 job to put them in.
There are inner and outer wheel bearings for that.
It has nothing to do with "how". It's how to do it *cheaply*. Thay got that
down pat.
How about investing in that stuff (capital improvements) *instead* of fuel
assistance? These toys end up subsidizing the rich.
