Jan Panteltje
On a sunny day (13 Jan 2004 14:57:11 -0800) it happened [email protected]
(Harry Conover) wrote in <[email protected]>:
I've cloned both Unix and Linux system disks and found that you have
it in and copy anything to anything else (runs from ramdisk).
http://www.8ung.at/spblinux/
There is also the Knoppix CD that will give you a Linux running from the RAM disk.
But I think you are wrong abou this, I did copy that harddisk from my running system,
lets try:
mount
panteltje:~# mount
/dev/hda7 on / type ext2 (rw) < Linux is now running here
proc on /proc type proc (rw)
devpts on /dev/pts type devpts (rw,mode=0620,gid=5)
/dev/hda5 on /boot type ext2 (rw)
shmfs on /dev/shm type shm (rw)
/dev/hdb1 on /video type ext2 (rw)
/dev/hdb2 on /reiser type reiserfs (rw)
/dev/hda1 on /big type vfat (rw,uid=500,gid=100) < windows 98 disk
/proc/bus/usb on /proc/bus/usb type usbdevfs (rw)
cat /dev/hdb > q1
I do rw-r--r-- 1 root root 52105216 Jan 14 01:54 q1
I now do ctrl C, not enough space.
See it DOES copy:
ls -rtl q1
-rw-r--r-- 1 root root 53223424 Jan 14 01:56 q1
What error message.
You may get stuck when copying /proc/ or so...
See, you need some practice, throw out that MS windows,
get a real OS.
To make a clone hd for a new PC avoiding your fears, you could
take a PC, stick source HD in IDE2 master and the empty in IDE2 slave.
Or use your Linux memory stick.....
This is ultra cool stuff, it allows you to take over any system...
Just enable USB ZIPDRIVE boot in BIOS![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have Linux on my USB memory stick too, so I am free to plugto shut down the OS and use a stand-alone utility program to do this
successfully, just as you had to do with VMS and Windows. (This is
precisely why the Red Cap distribution of Linux contains such cat /dev/hda > q1a
utility.)
lets try:
mount
panteltje:~# mount
cat /dev/hdb > q1
See it DOES copy:
ls -rtl q1
What error message.
get a real OS.
