F
Fred Bloggs
Terry said:Fred said:Terry said:Fred Bloggs wrote:
Terry Given wrote:
Fred Bloggs wrote:
Terry Given wrote:
I recently built about 50,000 of this circuit, with a feedback
cap too (mathcad rather than mathematica, and a pencil to start
with for the analysis), and 15 inputs thru 100k resistors. the
effect of the 14 "grounded" resistors shifted the center
frequency by about 10% - Aol was about 50. power consumption (and
cost) constraints meant I couldnt use a faster opamp, so instead
I stopped assuming and started calculating
What was the transfer function you were shooting for, and which amp?
a summing band-pass (ish) filter. 40 x TLV274.
I didnt want to AC-couple the inputs (that would have cost me 240
capacitors) so I used the bridged-T feedback network with an RC
shunt to give a DC gain of about 1/16 - any DC is basically
common-mode, and the next stage was AC coupled. 3 Rs and 2 Cs was a
whole lot cheaper than an RLC. But 100k/14 = 7k in parallel with
the -ve shunt arm, enough to move Fc 10% or so.
SPICE clearly showed it, so I went back and re-did my opamp
analysis using Dostals approach (originally I did it using the
Woodgate approximation), and voila - out popped the same answer. Mr
HP3577 also agreed with spice and mathcad. Dostals method also
allowed me to directly calculate the phase margin. Since then, I
have analysed all opamp circuits thusly - but I use the Woodgate
approach with pencil & paper as a bullshit detector
Cheers
Terry
You can achieve a wild increase in effective GBW by going to current
mode feedback. The peaking and rapid rolloff due to that low
impedance -ve shunt is eliminated from any frequency bands usable
with the voltage feedback circuit. The output gain of 2x deals with
the CMR input range of the TLV274- requires about a volt of headroom
to V+ - facilitation odds and ends not shown...
View in a fixed-width font such as Courier.
. >--[Ri]-+-------+------[R1]--+--[R2]------------+
. o | | [R3] +--[R]---+-->Vout
. | | +5V | | |
. | | | C | | |\ |
. o | | +-----||-+ +--|-\ |
. | | +-----[Rc]-----+------|+/
. o | | | | | |/
. >--[Ri]-+ | +-----------+ | [R]
. >--[Ri]-+ +------|>|---+ | | |
. >--[Ri]-+ +--------------------------+
. | | |\| c | |
. | +-|+\ |/ | | OA TLV274
. | | >-+---| c |
. 2.5V>-+-----|-/ | |\ |/ |
. |/| | e+ c
. | [Rb] e+
. | | e
. GND---------+--+-----------+------------
I'll study that a bit later. unfortunately it also achieves a wild
increase in parts count and cost - this circuit is replicated many,
many times![]()
I can't comment on your application since only you know what that is.
You may find this strange, but the idea is to overcome the limitations
of low inverting input shunt impedance and not to improve your product.
What about the typo? the 2nd transistor shorts out the +5V supply....
Cheers
Terry
It is a common collector pre-drive for the third transistor which is CE.
If extreme gain accuracy is not needed it can be pulled, the CE should
be a high beta type at low Ic.
