U
UCLAN
GregS said:I think there is a DVI ont the HD box.
There ya go! *That's* a digital output.
Digital with standard lines/frequency.
Sometimes, you're nonsensical. What does "...digital channels will go off the
air with NTSC bandwidth specs" mean? Digital has nothing to do with NTSC. And
"Digital with standard lines/frequency" ?? All NA video transmissions, be it
NTSC, ATSC SD, or ATSC HD are modulated into the same 6 MHz bandwidth. HD
video uses as high as 18.5 Mbps data rate, while SD typically is around
1-2 Mbps. Broadcasters are allowed up to 19.39 Mbps for their 8VSB modulated
signals. Some use the entire bandwidth (18.5 Mbps of it) for their HD channel,
while others use less for their HD channel, but add one or more SD channels.
Right now I have the RGB going to my new LCD HDTV works fine in HD mode. If
I connectec video to my old 36 inch CRT Toshiba, its not going to recognize
the new formats.
What "formats" ?? If you feed a digital signal into an analog monitor, it
won't tune the digital signal at all.
