Ok @73's de Edd, here's some voltages, all with respect to the chassis.
The heater windings (pins 1 and 11) are at -515V and -513V respectively. Pin 11 is tied to pin 2
The cathode (pin 3) is around 7V more positive than the heater due to the voltage drop across the 100kΩ cathode resistor (current is approx 70μA).
G1 (pin 2) is tied to the EHT and is also at -515V
A1 (pin 4) is at -303V
The deflection plates on pins 5 and 6 are at 188V and 184V respectively.
A2/G2 (pin 7) is at 88V
The deflection plates on pins 8 and 9 are at 180V and 189V respectively.
Pin 10 is N.C.
And we're back to pin 11 that was mentioned above.
The scope is in external timebase mode (effectively X-Y mode) with no signal and the trace is roughly centered (it's actually about 1/2 a division low and 1/5 of a division right)
If I move the trace all the way to the top of the screen, the collages on the delection plates do this:
5: 197V
6: 165V
8: 179V
9: 184V
All the way to the bottom
5: 167V
6: 195V
8: 179V
9: 183V
All the way to the left
5: 182V
6: 181V
8: 156V
9: 203V
And finally, all the way to the right
5: 182V
6: 181V
8: 199V
9: 160V
Ok, and as I check the positions of the astigmatism and focus controls, I find they're labeled back to front!!!! AND knowing this I can adjust the trace to a fine point!
The spot is a bit blown out in this image, it actually looks quite small.
Turning on the horizontal timebase we get this
And with a little tweak to the horizontal gain...
Woo hoo!
Now to rotate the tube a little too get the trace horizontal.
Pin 10 is N.C.
5: 197V
6: 165V
8: 179V
9: 184V
5: 167V
6: 195V
8: 179V
9: 183V
5: 182V
6: 181V
8: 156V
9: 203V
5: 182V
6: 181V
8: 199V
9: 160V
Woo hoo!
