i'm working on a defunct Mobility scooter speed controller, the relay that powers the forward is no longer functioning. I have determined that the relay is functional.
I am trying to use a transistor to activate the heavier load relay. I found the signal from the throttle control. It rests at 5vdc and as forward throttle is increased the Vdc increase to a max of 10Vdc. For the reverse the opposite happens and the Vdc decreases to 0Vdc. The solenoid that activates the reverse engages around 4vdc.
I want the Transistor to activate at 6Vdc and above and have a through put on the High power side of 24-40Vdc. I found a NPN 2N4401 transistor from Radioshack, from what I read it should be appropriate to my task.
I'm having trouble making it work though. Did I miss my understanding of how this transistor works or how it activates? It's my first time dealing with transistors and have been reading for several days and my brains mush.
