Hi everyone, i all my life have a passion for electronics, but i never study it, and recently i started to do some research about its basics and fortunately i understand a little bit, i maked some simple circuits and worked fine,
and now i maked a simple circuit i dont know what its can named or its type, this circuit is like the leds flashes ciruits it has two signal output, let say the 1 output and the 2 output, when the 1 is on, the 2 is off and then the 1 turn off and the 2 turn on and the cycle continues,
and the time between this circle is around 1 second but i want to make it very, very fast, so to do that from my understanding is to lower the capacitors value and maybe lower the resistors value without changing the circuit "circuit structure",
so i would like to know if i am correct or wrong, will the circuit work? or to do that the whole circuit must be changed,
the picture of the circuit below, and THANK YOU.
