need help for my circuit
Hi everyone, i all my life have a passion for electronics, but i never study it, and recently i started to do some research about its basics and fortunately i understand a little bit, i maked some simple circuits and worked fine,
and now i maked a simple circuit i dont know what its can named or its type, this circuit is like the leds flashes ciruits it has two signal output, let say the 1 output and the 2 output, when the 1 is on, the 2 is off and then the 1 turn off and the 2 turn on and the cycle continues,
and the time between this circle is around 1 second but i want to make it very, very fast, so to do that from my understanding is to lower the capacitors value and maybe lower the resistors value without changing the circuit "circuit structure",
so i would like to know if i am correct or wrong, will the circuit work? or to do that the whole circuit must be changed,
i appreciate your reply, and i will Look up to astable multivibrators, but do you have an idea if i reduce capacitors value like pf or nf capacitors to make the circle faster, does the circle will work?, because i dont have the tool to test that much of speed,
also i want to use this circuit for DC to AC, i will add to it another circuit contain MOSFTs, so i dont know if i am thinking crazy, thanks
You are correct about reducing component values to make the circuit oscillate faster. But not yet.
The circuit has several problems. Please add a reference designator to each component and re-post so we can discuss how they work. A reference designator is a unique label for each part. For example, label the transistors Q1, Q2, etc. R for resistors, C for capacitors. Label the outputs OUT1 and OUT2. also, add a GND connection to the right side of the battery.
This might sound picky, but it is important. Discussing a circuit without reference designators is very difficult, and causes many mistakes. A good, clear schematic is essential to learning electronics.
Also, ***all*** ground symbols point down.
ak
My apologies if I sound rude, but your circuit makes no sense to me. I rearranged the components and connections a bit to make it conform better to standard circuit diagram layout:
Note that I also labeled the two outputs with different names out1 and out2 to make it easy to distinguish between them. Unless you wanted the two to be connected, that is, which also makes no sense to me.
Since Q4 is always biased in the ON state, Q3 will always be OFF and the circuit is equivalent to this simpler one:
This circuit doesn't oscillate in my simulations. Out2 is at 12 V fixed, depending on the initial conditions (.ic command at the bottom of the screenshot) either immediately or after some time.
Your circuit will not work. Here is a common circuit that works, and a warning about damage if the supply voltage is higher than about 6V without using protection diodes.
thank you guys for your help,
i understand that i didn't add references in the circuit, its because the app that i am using for design, it does not allowed to write references,
also i builded this circuit with two LEDs and it work fine, but the time between them (flashes) is around one second,
i designed the circiut now on a pappaper.png er with references, also i have a video i filmed it when i tested this circiut, but i am not sure if this website allowed posting videos.
Your Q3 is always turned on which always turns Q1 off, then they both are not needed.
I do not see how your circuit works since it is completely different to the normal circuit.
Rather than have us guess, why don't you tell us: What is the purpose of Q1 and Q3 in your circuit?
ak
maybe i am wrong about something, i thought that if i made this circuit without Q1 and Q3 the circuit wont work, because i wanted that the line that feed C1 then to Q2 and the line that feed C2 to Q4 have the same value for perfect timing,
meaning : the resistors of line C1 to Q2 have the same value as the resistors of line C2 to Q4, so i thought in this way the Q2 and Q4 will work togather at the same time, meaning the circuit wont work, so i thought to make Q1 with lower value resistor to work first to cut current of C2 and Q4 to allowed current pass to C1 and Q2 first, in the same time current will pass to Q3 to cut current of Q1 to allowed current pass to C2 but current wont pass until C1 get fully charged.
I am showing your wrong circuit again and explaining its errors. I show the correct circuit again.
If the resistor and capacitor values are exactly the same, and the transistors have identical specs then the outputs will be perfect squarewaves with on times identical to off times.
A CD4047 IC has an oscillator built in and has a digital "divide by two" circuit to make two "perfect" squarewave outputs.
like i told you before it work fine, i build it and tested it with my hand, and i didn't do it for oscillator purpose, all i want is just a circuit that give a controlled alternating two signals to use it with another circuit that i will build to converting DC to AC,
i uploaded right now the video showing the operation of the circuit.
Since your supply voltage is 12V which is much higher than the 5V maximum allowed Veb breakdown voltage of the transistors as I showed earlier, then maybe the transistors are breaking down and dimly lighting the LEDs. Then the transistors are slowly being destroyed.
even if the power supply is 12v there is resistors to control power, is not?,
i am not educated about electricity, electronics, i never study it.
The datasheet for every transistor shows Absolute Maximum allowed voltages and currents.
The reverse-biased emitter-base of a transistor is always rated at a maximum allowed voltage of 5V or 6V.
A series resistor limits the current, not the voltage.
