The whole idea is to keep all connections under the engine
compartment....
Yeah, that was my point. With all the surgery I'd have to do in the
passenger compartment to get to the cigarette lighter wiring, the
requirement to do so would be a deal breaker for me. So the lighter
circuit is out of the question.
By the way... the Speed channel used to advertise a gizmo that
appeared to be an accelerometer-based performance monitor. I think it
was called a GTech Pro or something like that.
One of its advertised features was shift lights. That would imply
that their engineers had figured out some way of directly or
indirectly measuring engine RPM. Since its only connection was a
cigarette lighter plug, they must have picked up some sort of signal
from the DC feed. Maybe you could look it up and see if you can
figure out how they did it.
Another thought was your installation location. You mentioned that
you're installing your unit very close to the battery. Well, that
battery must be acting like a really great filter that's killing any
signals that might be of use to you. Maybe if you could move your
installation downstream a bit, you'd have enough inductance between
your power pickup point and the battery that you might have more
useful power line noise to work with.
Good luck!
Tom
