Hello all,
I am trying to develop a new type of aftermarket product that will
connect to a vehicles battery. Ground return will be through the
chassis. I desire no other electrical connections. This will help
simplify installation for the typical consumer. Do you know many
people who can't find their vehicles battery? Well, I'm sure you
could name a few. But, the majority of us can. What I want to avoid
is telling someone to splice into some signal within their vehicle.
This can get difficult. The type and location of such signals will
vary from one manufacture to another. Who knows, it may not exist at
all in some vehicles...
Oh yeah, one more thing. This product will be mounted in the engine
compartment so any electronics specified will need to be available in
extended temperature ranges.
When activated this product will draw about 5 amp. I'm trying to
devise a way to allow activation of this product only while the engine
is running (for obvious reasons). Therefore the product will need to
sense engine running. If this criteria is met, it will be allowed to
switch in its load. It will also need to detect when the engine has
stopped. At this point it will disconnect its load and go into a low
power mode. It will sit powerd up indefinitely in low power mode.
Therefore, whatever sensing scheme we come up with will need to draw
minimal current. Preferably in the neighborhood of 500uA or below. I
don't want to drain someones battery!
I have already tried electrical system voltage sensing with no
success. One would think that when a vehicle is at rest the battery
would sit at approximately 12.6VDC. When the engine is running,
system voltage climbs up to charging levels (typically 13.0VDC or
greater). However, what I find is that system charging voltages range
all over the map from one vehicle manufacture to another. For
instance, one vehicle manufacture in the USA typically charges at
14.00VDC. However, they also have a mode that will drop charging
voltage down to approximately 10.8VDC in cold weather. Another US
manufacture charges at 13.2VDC and also has its own version of low
charging voltage mode. Some European vehicles charge at 12.8VDC.
Then there is the inconsistancy in rest voltage of a vehicles
battery. A fellow co-worker has a brand new vehicle who's battery
rests above 13VDC! As you can see, this is all over the map. Where
would I set a comparator to allow activation of my circuit?
This got me thinking about alternate options. One thing I do know is
that the raw power feed on a vehicle is REAL noisy when the engine is
running. Is there a way I can use this to my advantage? Essentailly
what i would need is a noise detector. At rest the VBAT power buss is
quite. While the engine runs there is all kinds of crud superimposed
on it. One interesting nibblet is the pulse generated on the power
buss whenever a cylinder fires. Could I detect and latch on in the
presence of ignition pulses? A potential problem... The shape and
amplitude of these pulses varies from vehicle to vehicle. In one
vehicle we tested, pulses were about 600mV high. The highest peak was
about 2uS wide. The period between pulses was 50mS with engine at
idle. In another vehicle, the pulse was approximatley 1V in amplitude
but only a few nanoseconds wide! The period between pulses was about
25mS with engine at idle.
Can you think of a highly reliable way to detect engine noise, or
better yet engine running, through sensing of the vehicles battery
feed? Something that perhaps would throw a logic signal high in the
presence of engine noise and then bring it low when the engine is shut
off? This circuit would need to reject random EMI coming from other
sources than the vehicle. I don't want someones ipod setting off my
product while the car is parked in an airport long term parking lot!
Any help you can offer would be greatly appreciated.
Ge0
Ge0
