Hi, I've dug out a NAD 3020A Amp from my parents gathering dust corner and taken on the so far enjoyable learning process of attempting to diagnose and repair its issue(s).
It powers on, all inputs and outputs seem functional. But the volume - at maximum - is only a whisper. Left and Right sound balanced. And the 5 power lights (indicating 1-35W) don't illuminate - I presume this could simply be the globes or a deeper issue.
I replaced 4 main caps (2200uf 35v) because they had some visible corrosion/leaking on top. This resolved an idle hum which is reportedly common in this amp. The volume may now be marginally better but is still a whisper.
As a next step I removed and tested 4 main transistors (2N3055 and MJ2955). They seem to be open in the appropriate directions and showing ~300ohm resistance (30x10) as per pictured multimeter.
I see some brown glue around some caps which I've read may become corrosive. Otherwise all appear to be intact, albeit aged and potentially dried. I figured I'd seek advice and direction before tinkering with any of these.
To my eye the circuitry seems without abnormality. Except perhaps some orange/brown residue at some of the soldering points - see left hand side as pictured - these align with 4 fuses (intact).
Any assistance is much appreciated.
