If he does, it might not be their first clue ...
Interestingly, in the first few miles of each of its flights,
when it was flying, more than half the Shuttle's power
came from aluminum combustion. You might be interested in
the following thought experiment:
(1) Take a serious hydrogen car such as the recent BMW 750.
Like every such car it has a combustion motor
and a cryogenic liquid hydrogen tank.
Remove most of this tank's guts -- the vacuum
superinsulation, the heater, the 140-L inner tank.
Keep only the 175-L outer steel shell;
if you want, change it to aluminum.
(2) Put 63 litres of aluminum pellets into it.
(3) Replace -- this is a difficult step, but it's all the
same price to think about -- the hydrogen burner motor
with an aluminum-burning one.
As proof that such motors can exist, I offer the
space shuttle's SRBs. When the shuttle was flying,
the first 10 miles or so of every flight was
principally aluminum combustion-powered.
(4) Run the vehicle until all the aluminum has burned.
Pressed into small briquettes, the resulting oxide
should fill up about 96 litres of space, so it can
go back in the tank. In fact, it can have its own
compartment there.
(5) Note how far you drove: well over a thousand km,
over three times as far as is possible using the
same space for hydrogen.
--- Graham Cowan
http://www.eagle.ca/~gcowan/Paper_for_11th_CHC.doc --
How individual mobility gains nuclear cachet.
Link if you want it to happen
