Greetings!
Today I bought my second multimeter. It's a UNI-T UT-33A.
It works great and displays exact same numbers as my older UT-33D except the diode check but with LEDs.
It doesn't want to light up the LEDs like the 33D does because the diode check voltage is 1.6V unlike 2.9V of the 33D. Is it because the 33A uses 2xAA batteries insted of 1x9V battery like 33D does?
Can I somehow turn up the 1.6V voltage on the output so I can visually inspect the LEDs or should i just stick with it?
