The unit is (I believe?) to be a PIP-4048HC. 48V nom ... 4000w output.... I think 40A input for charging... either AC or solar.
These units have no model branded on them but info can be seen on the LCD IF/WHEN powering up.
I have given to me a non-functional MPPSolar inverter/charger that I've pulled down without even trying to power up.
Looks like this. (see below)
I took a picture of the main board after removing some sister boards & the long heatsink bolted to the mosfets etc.
(see below)
I can see all 8 mosfets or whatever are seriously damaged. On very close inspection I can see no other damage anywhere. The bigger ones are 8 of 1MBH75D-060S FE .... the ones blown are 8 of IXTQ96N20P.
Surely it wouldn't be as simple as replacing these 8 things?
(see below)
