Kevin Aylward wrote:
Eeyore wrote:
John Larkin wrote:
Eeyore wrote:
John Larkin wrote:
Eeyore wrote:
Learn something about LATERAL mosfets that were designed for
audio. I've already given part number and links to data sheets.
That doesn't really matter. The transfer function only needs to
be continuous so that you can close a loop around it, and the fet
needs to be able to stand the peak power dissipation. That can
easily be done with vertical "switching" type fets. A modern
FLOOD architecture [1] works great with most any kind of fet.
Lots of things have changed in the last few decades.
John
[1] Of course you've never heard the term before. I just invented
it.
Fine. Can you elaborate some more on it ? Laterals have some truly
lovely features for audio. The only downside being a slightly
highish Ron. Not really a problem when (as I have) used as many as
6 in parallel (12 mosfets per channel / 24 per amp). They also
match beautifully with no need for source balance resistors (so
some of the Ron loss 'goes away').
An opamp per fet, closing a local loop, feedback from the fet
source, makes each fet look like a perfect unity-gain, fast,
zero-offset device.
Interesting idea. I'll have to chew that one over. I can see
possible problems fron op-amp output overshoot.
I have a simple embodiment of that concept here, done a while ago, in
virtual land;-)
http://www.kevinaylward.co.uk/ee/circuits/VeryLowDistortionAmp2.jpg
Its a push/pull gain loop around the output devices, forcing them to
be unity gain followers.
You can get lower distortion, at the expense of speed, because you
have to compensate earlier.
Common mode feedback at the second stage, allows for enormous dc/lf
gain. cascodes to allow the use of fast small transistors to do all
the main work. Emitter follower buffer to reduce the current swing
in the input pair, as per doug self. Spice says it should be in the
< 0.0001% , 20Khz range, maybe...
Kevin Aylward
Kevin - an interesting circuit, and I appreciate what you have done
with the output stage, but I'm still wondering why you didn't include
it within the global feedback loop - that could only have made it
better, lower output impedance, more load insensitive etc etc etc.
