Jan said:
If you loo kat the TDA9274 datahseet (the ST DMOS chip), then in the
blockdiagram on page 2 you will see this is exactly what is done with
the lower output MOSFET, combined with opamp makes unity gain.
The top is already a source followwr.
The over current protection same thing, opamps.
It is likely this what makes the Boucherot network not needed.
I doubt it. I haven't seen the data sheet, but it is not usual to be able to
stabilise an amp with what I believe you are describing here.
Consider one amp feeding the other, both running open loop, with overall
feedback, to the 1st. Now consider the case where the second amp is
configured with local feedback, to make it a unity buffer, following the 1st
amp. Naively , one might argue that the 2nd stage now has a wider bandwidth,
due to feedback, such that the "new " system might be stable, i.e. one main
rolloff due to the 1st amp. However, in realty, topologically, nothing
changes. The determine the stability of the system, one needs to break the
loop at a point that breaks *all* feedback paths at once. This point will be
the point directly at the output of the 2nd amp. when this is done, it is
clear that the stabiliy is still due to the total loop gain of both amops
cascaded.
Excepting for the special cases, e.g. , where feedback is used to neutralise
r.f amps, feedback in general, cannot be used to widen bandwidth, if the
purpose of that wider bandwidth is to achieve stability, in this type of
arrangement
To wit, There is no such thing as a free lunch...
Kevin Aylward
www.superspice.co.uk
