Tim Ward
daestrom said:You don't *need* the peaking generation if the major load during the 'peak'
is related to sunshine (i.e. A/C load). The 'peak' in winter time for some
areas is non-existent. Unfortunately for me, in NY, the peak in winter is
about the same as summer, so PV is *not* a winner here.
But in places like southern California, or Florida, where much of the daily
'peak' is caused by A/C, the peak load disappears on rainy days and 'darker
months'. Don't need a lot of peaking generation to supply a load that isn't
there.
So supplying some or a major portion of 'peak' load with PV is a good match,
*in those specific circumstances*. The fact that PV is a lousy fit where
you are is bad luck. But don't be so provincial that you can't see that
other locales are different and can make better use of PV.
daestrom
Yes.
Interestingly, (to me at least) the solar thermal peaking plant at Kramer
Junction nearly went bust when natural gas prices went up a few years ago.
It turns out the steam for the turbines can be generated either by natural
gas, or the solar array.
Apparently, the peak price times the availability of just the solar array is
not profitable -- at least if you're having to guarantee availability.
They're still running, as far as I know, so they must have figured out
something.
Tim Ward
