This is my circuit.I'm trying to measure the current by using an resistor(250 ohm) across the negative power supply given to the instrument.
For that instrument 24VDC power supply is used.I connected the positive voltage directly to instrument.Negative supply from the 24VDC SMPS is connected to 1st pin(GND) of IP connector.The 2nd pin of connector is connected to instruments negative side.
It working fine.I can measure the current taken by the instrument.But sometimes it malfunction...It will take 4 to 20mA current.
