Hello everybody, well I'm working on project that consists on monitoring temperature, current intensity and rpm of an ac motor.
By now I'm using a current transformer ring type that provides 1 ampere every 50 amperes, so my idea is to rectify the current provided by the current transformer and then pass it on a current to voltage converter, the voltage will be used on a PIC 18F4550 ADC channel.
The circuit that I want to use for rectifying is the one that I've uploaded on this post. The opamps are used for compesate the voltage lost by the diodes.
I know the circuit may not be the best way to rectify a signal... but opamps are cheaper than the modules used for this applications, and I don't think that I can easily get an specific IC for this task on the place I live.
Could this opamp configuration help me? if not is there some other configuration that can help?
Another question is that I'm using 741 opamp for current to voltage converter, does 741 opamp can afford currents between 500mA and 1 amp?
