Hi all,
I’m using a LT3080, and I have a problem. (See attached) If the LT3080 does not have a current draw on its output (pin 3) of a least .5mA it will not stay in regulation. A LM334 was added to the output to keep it in regulation, but the problem is the LM334 operates only down to 1 volt, therefore as the voltage drops down below a volt the LM334 will no longer operate, and the LT3080 will be out of regulation (you can’t get it below ~2 volts)
In the attached schematic I show the bread board, and I can only get it down to 2.4 volts even after grounding the set pin. Does anyone know how to keep it in regulation and get “0” volts as an output?
