Hi all, doing a little research on LDO linear regulators and came across a five pin package that I was not familiar with.
http://cds.linear.com/docs/en/datasheet/3080fc.pdf
In the schematic above they show Vcontrol being tied to the IN pin. In the pinout diagram they show Vcontrol as a separate pin as well as a n/c pin. My first thought was why isn't Vc internally connected and the NC omitted and this whole production could be offered in a 3 pin package?!
From what I read of the datasheet, they state that the current across the reference resistor sets the Vout.
Does the mean that the pin is there to allow for a different current fed through Vcontrol than provided by the supply input?
Is there another reason for the extra pin and it not being internally tied together?
This could be a possible candidate instead of the LM317 for the bench psu due to its LDO of 0.35V at 1.1A. It also has a low thermal resistance of 3deg C/watt. Worse case scenario, 19 watts x 3 = 57deg C plus ambient, no heat sink would even be required!! Pretty nifty IC - also has current limit with foldback and temperature protection.
Does soft start work in this schematic because of the delay until C1 is charged? What purpose do D1 and C2 serve?
In this paralleled design, does the full current run through the second LDO? I see that the pot R4 is a meg Ω whereas the first pot is only 100k. Would both pots have to be rated for those loads?
Thanks in advance!
Thanks in advance!
