LM34 / capacitor / PIC ADC interaction? Aaaaarrrgh!
Robbo
I'm running a couple of LM34 temp sensors into a PIC16F687. When running the
ADC result is noisy.
Here's what I've got:
1) On the LM34 temperature output pin is a sawtooth of about 200mVpp and
150uS period: |\|\|\|\|\
The 150us period seems unrelated to the ADC sampling rate - this which is
sampled "on demand".
2) The ADC is set up for external reference (2.5V) which is clean and
stable.
3) The LM34 supply and grounds are also clean and stable. I've tried
powering them from both 5V & 9V (battery).
4) A couple of 5k pots set up on the input work perfectly, the wiper
voltages & ADC results are stable & smooth.
5) The LM34 outputs are coupled via a 10 ohm series resistor followed by a
10nF cap to ground as follows:
LM34 --/\/\/\---------> ANx on PIC
10R |
--- 10nF
AGND
6) Stuffing around with the code, reducing it to the bare minimum does not
change anything.
_However_ I've found that removing the 10nF capacitor _fixes_ the noisy
operation of the LM34's. With the cap in it oscillates - with no cap it is
stable. I can't see anything in the LM34 data sheet about capacitive loading
the LM34 output. Zout is low 0.4R @ 1mA.
Am I missing something obvious here? Any suggestions greatfully received!
TIA
r.
Tim Wescott
the ADC result is noisy.
is sampled "on demand".
stable.
a 10nF cap to ground as follows:
10R |
--- 10nF
AGND
not change anything.
is stable. I can't see anything in the LM34 data sheet about capacitive
loading the LM34 output. Zout is low 0.4R @ 1mA.
received!
TIA
r.
The LM34 probably has an op-amp at its output (or the equivalent), and op-
amps are notorious for not liking to work into a capacitive load.
Increasing your resistance into the cap would probably also make the
thing happy, if it didn't cause problems elsewhere in the circuit.
Tim Wescott
Control systems and communications consulting
http://www.wescottdesign.com
Need to learn how to apply control theory in your embedded system?
"Applied Control Theory for Embedded Systems" by Tim Wescott
Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
Robbo
Tim Wescott
Thanks Tim - I told myself I'd read that data sheet a dozens of times -
until I hit the send button!
Right under my nose is this big section subtly titled CAPACITIVE LOADING.
Apologies.......
nospam
"Like most micropower circuits, the LM34 has a limited ability
to drive heavy capacitive loads. The LM34 by itself is able to
drive 50 pF without special precautions"
Taken directly from a National LM34 datasheet.......
you are probably sending the amp intom current hugging put the resistor inside the loop of the amp if you can or remove the cap all together i don't see the reason for it .
