Ok thanks bob I will make a 4 diod rectifier and test that , I will let you know soon
Platforms
Content
Modemhead Should I connect up to the transformer or should I check anything els first
Four separate 0.605 readings one way, and four separate open readings the other way, right? If so, then the bridge must be OK.Yes I am getting 605 on the meter both sides of thr bridge , the meter stays on ( I ) on reverse.
Have you verified the regulator is behaving as expected, like we did before with the two meters?Should I connect a transistor , these are new transistors I have metered them too at 690 to 710 all have different readings , to be honest I was expecting to see a 0.5 or somthing like you two have mentioned before as I have not powered them yet.
