It is all earthed im not that much of a noob bluejets lol
. It was just my first circuit build and I didnt know how to understand pins of components and drawings , not knowing that basic stuff causing me to massivly fail ... i have done house wiring a few times in my life and know all the dangers
, but I do understand your concern there its fine the transformer and faceplate are earthed , all of the screws are screwed into wood
look lay across the top of transformer you see a earth wire ready for mounting to face plate
See the screw on this Next pic just to the right of the amp gauge next to the M
i would like to know if there would be a way of adding adjustable current limiter to this for testing other projects by putting in a similar circuit just before the v adjust and directing power to a load to suck up current , but then i figure i would be loosing my volts and cook the transformer with the load required to draw almost full 15A "so is it possible" has any of you cheated ohms law and found a way around this
or is it going to have to be a additional 16v transformer with very low ah for the volts ?
