pimpom
Tim said:Why, then, does it work to make up multi-strand wire bundles
for SMPS
service where the wires are just lightly twisted into a bundle?
Are
these getting one part of the way there, but not all?
I had heard about the Litz wire 'gotta be a magic braid
pattern', but
then I've seen all these SMPS transformers that just have
almost-parallel strands.
One reason for using multi-strand wire even at mains frequency is
that it utilizes winding space more efficiently than a single
wire of the same cross-sectional area. Another reason is that
multi-strand is easier to handle because of its greater
flexibility. I've experienced both effects in practice.
I can't speak authoritatively about the use of simple-bundled
wire in SMPS transformers, but my guess is that it's a compromise
of cost, availability and effectiveness. Individually insulated
strands bundled in parallel should exhibit less skin effect than
a large single wire, though perhaps not as effectively as
specially braided true Litz wire. And at least some manufacturers
are probably using it without investigating the effectiveness.
