On Fri, 19 Feb 2010 21:14:27 -0800, life imitates life
:On Fri, 19 Feb 2010 16:18:49 -0600, "Tim Williams"
:>I actually have some copper rope, which is about 1/4" diameter and looks to
:>be made of 28AWG or so. I don't remember how many strands it is, but if I
:>guess the rope is wound from 7 strands of 31 strand twist, that's 7*31 =
:>217.
: The problem is that it not being constructed from individual mag wires,
:it is "seen" as a single strand to the current flow, and having only ONE
:skin. The litz configuration requires the wire be discreet from each
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
ther with the exception of the termination points.
I hope you don't mind a little bit of layman's interpretation as an assistance
to the OP but what you mean by "mag wire" is that each individual strand which
makes up the total x-sectional area of the litz conductor MUST be insulated from
every other strand. If the strands aren't insulated then the skin effect will be
the same as if a single strand of the same overall x-sectional area had been
used - and this is no good for high frequencies.
