Dave Plowman (News)
Was it a Bogen intercom? They are a division of Lear Sigler. I worked
there at one time, years ago.
Beeping out each line should have been easy.
I've yet to see an unmarked multi-pair cable.
Try figuring out where 50+ pairs of audio cables go on a large school
intercom system, after some idiot kid rips all the wires loose, AND
removes the tags. It took two full 8 hr days.
"I" was a euphemistic "I", idiot.
As in I that represents any joe sixpack homeowner.
One does not need 16 Amp per outlet capacity.
Where, at twice the voltage, you need it even less.
Spurious said:If you paid California electric rates, you wouldn't use it very many
times a year.
Spurious Response said:If you paid California electric rates, you wouldn't use it very many
times a year.
It must be nice to be able to build everything higher output, more
consumptive. We have to conserve here. Miniaturize.
What types of appliances get used in Japan? High wattage? Low?
Other places?
times a year.
I'd say it depended on the quality of the fitting
The problem is transmittable, thus only one bad socket was needed for
the problem to occur and spread to the others. So good sockets went
down too.
The way it occurs is one bad contact occurs, the plug pins get
damaged, and when damaged pins are inserted into a good socket, bad
contact occurs due to copper oxide and a rough surface. So the good
socket is damaged. Plug something else into it, that plug gets damaged
etc.
Slow process, but have seen it happen. AFAIK its the only electrically
transmissible disease
- given most plug/socket
arrangements have round pins. Including the heavy duty BS4343 type.
Nowt wrong with round pins. The problem is that some of the older
sockets didnt implement contact springing, either at all or
effectively. Sometimes the split plug pin was the only sprung part,
which is no good at all on 15A 3 pin plugs.
NT
times a year.
Thomas Tornblom said:Switching to 25A fuses
solved that. After the heatpump conversion I can most likely go back
to 20A fuses and save some on the electrical bill.
bz said:How would going to 20A fuses save some on the electric bill?
Apart from the fact that the energy used in a more powerful kettle is
slightly less, the rates in California appear to be about 12-15c/kWhr,
compared with my UK rate of 9p (~18c). The big difference in costs here
is that the climate is such that we don't need (and most of us don't
have) air- conditioning.
Paul Burke
Joel said:Really! I'm amazed... I thought Romex really had taken over the country
completely... does some locality think Romex is dangerous? Or they just
haven't updated their electrical codes to take it into account?
Hey, Louisiana was the last state to finally outlaw cock fights, doing so...
today. Hmm...
bz said:Bet you got a 'buzz' out of that.
Spurious said:Was it a Bogen intercom? They are a division of Lear Sigler. I worked
Dukane
Dave Plowman (News) said:I've yet to see an unmarked multi-pair cable.
Wolfi said:Good luck plugging in a switchable 1200/1500W electric room heater, when 1200W
just don't warm enough or a fix power 1350W type or a decent µ-wave.with 1kW
or 1.1kW *output* power, sucking about 1.5kW out of the wall.
Because initially we had been talking about wall outlets and according
plugs, with flat (US, UK) or round (most of Central Europe) contacts
and those connectors are rated 15A/130V (US) or 16A/250V (Europe).
So when talking about alternatives, we have to stay in the same
ratings range.
On Wed, 04 Jul 2007 11:05:44 +0100, "Dave Plowman (News)"
Other places?
