Spurious Response
"I" was a euphemistic "I", idiot.The standards aren't set around one person's requirements.
Graham
As in I that represents any joe sixpack homeowner.
One does not need 16 Amp per outlet capacity.
Graham
Spurious said:"I" was a euphemistic "I", idiot.
Spurious said:If I do not need 16 A power feeds as a result of not having any 16 A
power requisites, then why would I need a 16 A cord and receptacle
system?
For example, my 7.5 amp 230v Dyson DC-14 vaccum cleaner. The 120 volt
version draws about 15 amps.
I seem to remember having a 12 amp or so toaster and hot water kettle in
the U.S. Ours here are 1000 watts.
Dave said:That would suggest an approx 2.5 HP motor. Is it really that large, or is
that the start up current?
Yes, it's really that large. Dyson is a well known English brand, look
it up. The exact model is DC-14 animal.
Dave said:I know what they are having fixed several. And seen many more on the
council tip. A triumph of hype over common sense.
Not only is it the best engineered appliance I've ever owned, it's
the best vaccum cleaner I've ever owned. Dyson's design was so
good that Hoover stole it and was sucesfully prosecuted for
patent infringment.
It works well, and my totaly nontechnical wife can field strip it
if it gets jammed, which is almost impossible.
It's widely used in Europe.
Graham
John said:Why don't houses come with schematics?
John
bz said:Figuring out what fed what was fun.
Wolfi said:Or should you mean that type, which is used for computer monitors and -power
supplies?
If so, then you surely noticed the lousy Ampère rating of mere 10A for it,
which is just 2.3kW, rather than the 3.68kW which you have with a 16A
connector system?
Spurious said:Where, at twice the voltage, you need it even less.
Michael A. Terrell said:That is the IEC connector. It allows different cords to be used with
the same equipment in multiple countries.
Have you ever had a desktop computer OR monitor that drew 3.68 KW?
They were designed for exactly what they are used for: Portable, low
power equipment.
Wolfi said:Am 02.07.07 21.35 schrieb John Larkin:
Oh yes, it easily becomes a big deal as in case of an electric floor heater.
Some moron in the past had moved it around so violently while being plugged
in, that both contacts had been bent to at least 45° off direction befor it
came out of the socket and when I tried to put them straight again, one of
them broke off. I had quite a hard time to find a screw on replacement plug.
This is very common for transformers (which many people use here to operate
120 volt appliances brought in to avoid high taxes and huge markups) and
UPS's for computers, both of which are sold as being rated in WATTS,
but really are rated in VA which are 1.414 times as much.
A 1000 watt kettle would take forever to boil. UK ones are normally
2500/3000 watts.
Try figuring out where 50+ pairs of audio cables go on a large school
intercom system, after some idiot kid rips all the wires loose, AND
removes the tags. It took two full 8 hr days.
power equipment.
If you paid California electric rates, you wouldn't use it very many
times a year.
It must be nice to be able to build everything higher output, more
consumptive. We have to conserve here. Miniaturize.
What types of appliances get used in Japan? High wattage? Low?
Other places?
