With a gain as high as 201 times and without diodes to limit the output swing to 1.2V peak-to-peak, the opamp output will be 7V peak-to-peak (when the opamp supply is 9V) that might overload your amplifier input, because the opamp output will be clipping like crazy making squarewaves. An opamp output that is clipping sounds harsh, but with diodes in the feedback loop the clipping is still distortion but sounds softer.
All old vacuum tube guitar amplifiers had an input resistance of at least 1 million ohms to produce high frequency sounds of the pickup.
A lower load in the pickup reduces high frequencies causing a muffled sound. The old 741 and 4558 opamps had a minimum input of 300k which muffles the sounds a little.
The distortion pedal circuit in post #107 has an extremely low input resistance that needs a transistor buffer to increase it.
