Frank Mikkelsen wrote...
Ian wrote...
Is it possible to make the feedback loop stable when adding emitter
followers in the loop (when using op-amps with bandwidth that high)?
Or is the output emitter follower uotside the loop?
I wouldn't waste time attempting it inside the loop, certainly not
with those parts. Outside the loop is a non-starter, unless you're
considering a class-A circuit.
I'd start by taking bench measurements on the current capability of
BUF634T buffer ICs at their full slew rate, to evaluate paralleled
opamps. BTW, Burr Brown (see AB-101) says series resistors aren't
needed because of the amplifier's internal 10-ohm output resistance,
but you may find some added external resistance may help it to deal
with a capacitive load. You may also find an R+C network to ground
helpful in reducing ringing.
I previously suggested evaluating inductor peaking of the capacitive
load near 30MHz to shift the phase of the current, or to reduce the
voltage swing at 30MHz, either of which can reduce the stress on the
amplifiers. Something along those lines may be part of your solution,
but a quick calculation reveals you may also have serious problems
involving inductance. For example, if you have a high-capacitance
electrode at the end of some coax, what the electrode sees at 30MHz
won't be what you're sending at the start of the coax. Also, simple
wiring may be a problem. Consider, even a modest 250nH of wiring
inductance resonates with 300pF at only 18MHz. Sheesh! One wonders
how your 300pF is constituted, and what inductances are involved.
Your first task should be to evaluate these issues. Often a spice
simulation can be helpful in evaluating a circuit with many complex
elements.
