Joerg
I've done it twice - once for real, with an 800MHz clock and GaAs
counters for the coarse intervals and a built in time to voltage
converter to work out when the trigger arrived within the the 1.25nsec
clock period. My 800MHz clock was poor and we had about 60psec of
jitter on the sampling edges.
A few years later I redesigned the delay-generating part of the
circuit around a 500MHz clock (which would have been crystal
controlled with less than a picosecond of jitter) and ECLinPS counters
for the digital part of the delay, and I was planning on using the
MC100E195 for the fine delays - it offered 2nsec of delay range and
20psec resolution. The MC100EP195 looks even nicer.
The delays through the MC100E195 are temperature dependent, and the
design did depend on recalibrating these delays against the crystal
controlled clock every few minutes, by using the system to set up a
pulse-width modulated waveform and digitising the DC level to find
what each delay really was. We should have been able to run through
all 128 discrete delays within a millisecond or so.
That's where an electronically controlled servoed delay line comes in,
to do the calibration automatically.
